Samsung RS2556 Side by Side Refrigerator Logo
A
Anonymous Posted on Jul 10, 2014
How do i force defrost on my maytag side by side refrigerator defrost using freezer up or down keys
Jorgie the appliance guy
Level 3:
Top Expert:
  • Samsung Master 5,639 Answers
  • Posted on Apr 10, 2015
Samsung Master
Level 3:
Top Expert:
Answers
5639
Questions
Helped
1522474
Points
32630
To check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS .
Maytag sxs; freezer frosts up no defrost + runs all the time + fridge side is cold.? Thanks.
Try to turn the defrost timer manually to force into defrost. If the frig defrost the ice then replace defrost timer. If unit dose not defrost the ice then check defrost heater and replace if needed.
Maytag refrigerator model number rsw22eo having problem with freezer not defrosting
You have a=>68233-3 Defrost Timer mounted somewhere behind the kick plate at base next to floor. Can you turn the timer slowly clockwise until the compressor and fans stop? I want you to force the refrigerator into defrost. If after 30 minutes the refrigerator does not restart running again replace the defrost timer. Once you place the refrigerator into defrost the elements should melt the ice that has been building up. If placing the timer into defrost does not help you will need to replace the=> 61001846 Defrost Heater Assembly . I am here if you have questions, John Tripp Appliance 911
Contact me here.
1helpful
My freezer has an ice build up. The drawers are frozen and will not move. I tried defrosting it and cleaning it and the ice built up again.
OK most refrigerators have 3 parts that operate the defrost and if even one of these parts fail you end up with the no defrost conditions. I cannot find any photos of the defrost heater but can show you the location in this photo description=> MFI2568AEW_Freezer_Section_Parts_Breakdown Looking at that photo shows each part numbered and part listed as 17 is the defrost heater part number=> 67006386 Heating Element or here=> 67006386 Heater also in that photo is the defrost thermostat=> 67006387 Defrost Thermostat or here=> 67006387 Thermostat like before there are no photos. Click=> Defrost Heater and Defrost Thermostat Instructions removal and re-install Instructions How to test a defrost heater click=> Here Now the first thing I want you to do is Force defrost is performed by using your Freezer Display and Refrigerator keypad. Enter the Forced defrost Mode by performing the following sequence of events.
1 Press and hold the Door Alarm Keypad button.
2 Press and hold the Refrigerator Temperature Keypad - minus sign
3 Release the Door Alarm Keypad and wait 3 seconds. Fd appears in the Freezer Display
4 Press the Refrigerator Down Keypad - minus sign Again. Sh should appear in the right display
5 Press again to Force Defrost Fd and Sh will flash in display indicating unit is in defrost.
If you have any problems please let me know here or on my websites HERE Thanks Sea Breeze
2helpful
HOW DO YOU PUT REFRIG IN DEFROST MODE WHEN IT HAS ELECTRONIC DEFROST CONTROLLER
You didnt give the make of the ref.; But your solution is here for most all
The newest defrost feature in modern fridges is the electronic adaptive defrost control board. *Maytag has one version, see picture...to put this adaptive defrost style of fridge into defrost, short with a small screwdriver between L1 and test on the adaptive defrost board, wait 3 seconds and you should hear a "click" noise from the relay and the fridge will shut off and go through a defrost cycle. A close up common way *this* version of the Maytag/JennAir control is wired.
Amana also has a version of adaptive defrost, see info sheet for some help on the Amana version. Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
Frigidaire has also jumped into the market with an adaptive defrost board. The fresh food section light switch and light bulb must work. To initiate a defrost cycle, open the door and push the light switch in and out 5 times within 6 seconds. The compressor and fans should shut off and the defrost heater should come on. Open the door and push the light switch in and out 5 times within 6 seconds to remove the refrigerator from the defrost mode and back into a cooling mode.
Frigidaire - referance model FSC23F7DSB3
This product comes equipped with an Adaptive Defrost Control (ADC). To activate manual defrost, press and hold the Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. A ?¿½d?¿½ in the freezer temperature window and ?¿½F?¿½ in the refrigerator temperature window will display when the heater is activated. To deactivate manual defrost, press and hold Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. ?¿½d?¿½ and ?¿½F?¿½ will be displayed until the defrost cycle is complete. (approx. 8 minutes)
For some Whirlpool refrigerators - some Kenmore refrigerators are made by Whirlpool ( 106.######## )
The refrigerator/freezer defrost system can be checked by manually initiating a defrost cycle. There
are two methods of initiating the ADC Test Mode.
First Test Method:
1. Turn the thermostat off for 15 seconds.
2. Turn the thermostat on for 5 seconds.
3. Turn the thermostat off for 15 seconds.
4. Turn the thermostat on for 5 seconds.
5. Turn the thermostat off for 15 seconds.
6. Turn the thermostat on for 5 seconds.
7. Turn the thermostat off.
In 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal closed). NOTE: The test mode will terminate when the bimetal opens. If the refrigerator/freezer is already in defrost, Test Mode can be terminated by unplugging the refrigerator/freezer from the wall outlet and waiting 30 seconds before plugging it back in. The refrigerator/freezer should immediately go into cooling mode if the thermostat is closed.
If this first test procedure fails to make the ADC initiate a defrost cycle, try the following procedure to make the ADC begin the Test Mode.
Second Test Method:
1. Disconnect the refrigerator/freezer from the wall outlet for at least 30 seconds.
2. Turn the thermostat off.
3. Reconnect power to the refrigerator/freezer.
Within 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal close). If the unit fails to go into the defrost mode during this test, the problem may not be with the ADC. A defective bimetal may be the cause of the failure. The ADC will only go into a test mode if the bimetal
is closed. If the ADC senses an open bimetal it will return to the cooling mode within 3 to 8 seconds.
HELPFUL HINT: Upon entering the Test Mode, the relay mounted on the ADC board should turn off the compressor and turn on the defrost heater. Listen for the relay to click.
?¿½ If the relay clicks one time when entering the Test Mode, check for continuity in the defrost heater.
?¿½ If the relay clicks two times, check for an open bimetal.
Maytag S-S Refrigerator MSD2756GEW forcing defrost cycle
I replaced my defrost heater two weeks ago, but the frost built back up on the evaporator coils. Replaced the adaptive defrost board with new ( Maytag p/n 6100598 8 ) board. Want to force a defrost cycle to see the heater work, so I shorted the L1 pin to adjacent pin (now called DOOR instead of TEST) for three seconds and nothing happens. Compressor keeps running, fans still going etc. Tried pressing the door switches 5 times in 6 seconds and that doesn't work either. Any hints on how to get the defrost cycle to initiate?
This might help, a copy:
The issue is that some 12002104 ADC boards have been shipped in the 61005988 ADC board box. Do not reorder the board, the 12002104 board will function the same in place of the 61005988, but you must use the forced defrost method for the 12002104. Jumping "L-1" and "door" will not initiate the forced defrost function.
To Initiate Forced Defrost Cycle:
Cycle cold control on and off three times in six seconds. The cold control needs to be left in the closed (call for cooling) position for the defrost system to energize on all platforms. It is not enough to cycle the cold control knob, the contacts must actually open and close (open doors for a period of time if necessary to force the control to call for cooling). In most cases, you can hear the contacts open and close if they are doing so.
To Terminate Forced Defrost Cycle:
Disconnect power for five seconds.
You were right. I cycled the cooling controls three times and it went into a defrost cycle. Thanks.
Freezer works but refrigerator does not
First, open the freezer and look for a snowy frost build-up. See if it's bad enough to cause bulging in the inner panel at the back. If so, you may have a defrost problem. Also, make sure nothing is blocking the ariflow between the freezer and fresh food sections.
Listen to see if the compressor is running. If it is, open the refrigerator side and turn the freezer control off, then back on, three times within six seconds. Did the compressor stop running? If not, the problem is very likely the adaptive defrost control board. Replace it.
If it does stop after "forcing a defrost cycle", you probably have a burnt-out defrost heater. It will need to be replaced.
1helpful
2answers
Maytag MSD2556AEW coils are freezing
you may want to replace the defrost thermo as it is most common / the defrost heater is probably ok / then the ADC / hope this helps .. ****
2helpful
2answers
Maytag refrigerator side stopped working; freezer is fine. WHY?
sounds like a defrost problem maytag has problems with the defrost thermostat use a hair dryer to melt the ice on the coils and see if the defrost thermostat is swelled up on the edge
2helpful
MAYTAG PLUS, MOD MZD2766GE STOPPED COOLING ON THE RIGHT SIDE,
After they replaced the part did they defrost the unit. there is probably ice build up on the coil behind the service panel in the freezer compartment. If the defrost control was the part replaced you can probably push the refrigerator side light switch in and out 5-6 times and force a defrost. if the unit goes into defrost then all the components are fine and you just need to manually defrost the coil either by off loading all food and leaving the unit off for 4-6 hours with doors open. of offloading freezer side remove rear access cover in freezer exosing evaporator coils and use a hairdryer to defrost the ice accumulation. good luck Peyton
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
