Question about Life Fitness Exercise & Fitness
How do I fix an overspeed error on T3 model?
I am getting an overspeed error on my T3 model. How do I resolve?
Keeps throwing up trouble codes p1506,p1151,p0302,p0171
Definition of Diagnostic Trouble Code P1506 Audi: Closed Throttle Position Switch Does Not Open/Short to Ground BMW: Idle-Speed Control Valve Opening Solenoid Control Circuit Signal High Ford: Idle Air Control Overspeed Error (see P0507) Jaguar: Idle Air Control System RPM Lower Than Expected - B Bank Kia: IAC Valve Opening Coil Voltage High Lincoln: Idle Air Control Overspeed Error (see P0507) Mazda: Idle Air Control Overspeed Error Mercury: Idle Air Control Overspeed Error (see P0507) Porsche: Throttle Jacking Unit Lower Mechanical Stop, Signal Implausible Volkswagen: Closed Throttle Position Switch Does Not Open/Short to Ground Volvo: IAC Valve Opening Signal
Definition of Diagnostic Trouble Code P1151 Audi: Bank1, Long Term Fuel Trim, Range 1 Leanness Lower Limit Exceeded BMW: Oxygen Sensor Heater Circuit Signal Intermittent (Bank 2 Sensor 1) Ford: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Lean Jaguar: Lack of H02S-21 switch, sensor indicates lean Land Rover: Lambda control limit bank 2.Implausible signal/condition Lincoln: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Lean Mazda: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Lean Mercury: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Lean Subaru: HO2S-12 Heater Circuit High Input Toyota: Coolant Path Clog Up for Coolant Heat Storage System Volkswagen: Bank1, Long Term Fuel Trim, Range 1 Leanness Lower Limit Exceeded
Definition of Diagnostic Trouble Code P0302 Category: Powertrain Definition: Cylinder 2 Misfire DetectedNote: This definition of P0302 is applied to all manufacturers
Definition of Diagnostic Trouble Code P0171 Category: Powertrain Definition: System Too Lean Bank 1Note: This definition of P0171 is applied to all manufacturers
Jun 17, 2015 | Cars & Trucks
How do i resolve error 20
There has been a malfunction of the mechanisms!
Turn the power off and remove then re-install the battery.
Turn the power on again.
Should be reset now!
Oct 18, 2014 | Canon EOS 1100D / Rebel T3 Digital Camera
Generac Guardian 12 KW Model 04456-2 shuts down on overspeed in cold weather
Leigh,
See my 5/22/12 comments on my "overspeed fault" problem resolution [Generac 43903 standby Generator overspeed indicator on starting] . If it only runs for a few seconds and then quits, you may have a similar condition to the one my unit had. A good technician should be able to diagnose the problem and determine if you have a similar failure to the one I had, or one of the other causes suggested by RSG000.
Jan 20, 2012 | Generac 13,000 Watt / 13,000 Watt Home...
When I turn on I get an overspeed error and machine shuts off. If I start it at a faster speed the speed fluctuates. I pressed start and menu and the LED says 3.5 but the diagnostic reads 6.8
Your speed sensor is not working properly this part is located under the motor shroud and on top of drive motor it is attached to a bracket with 2 bolts. Unplug the unit and remove motor shroud see if you can adjust it first by loosen the 2 nuts and moving the sensor forward without making contact to the flywheel, then tightened the nuts up. Plug the unit into the outlet, start the unit, if you still have the overspeed then replacement of the sensor is needed. Call Landice Directly they will ask for model and serial number and they will the new sensor.
Jun 28, 2010 | Landice L7 LTD Executive Trainer Treadmill
What does FET Error mean on my treadmill
Fet error is caused by the drive component(s) on the motor control board going open circuit or faulty. This is caused by poor power supply or excessive friction on the running belt which in both cases leads to excessive heat build up in the control electronics.
The Motor controller will need to be repaired or replaced and the heat issue resolved.
Apr 18, 2010 | Life Fitness T3 Treadmill with Advanced...
I have a Life Fitness T3-0 which shows a "FET error".What does that mean?
FET Stuck on Error / Err 5 - This error is probably caused by the driver transistor on the motor controller is detected to be shorted out. The fix is replacing the motor controller.
Jan 13, 2010 | Life Fitness T3 Treadmill with Advanced...
Trying to put TurboApps to Tungsten T3, getting error message
This 3rd party app may not work with your unit. Was it downloaded for palm device
Jan 06, 2009 | Palm Tungsten T3 Handheld
T3 sync with Outlook works except for Tasks
A hard reset of my T3 and sync with 'Desktop overwrite HH' on all Outlook conduits seemed to have resolved the problem.
Sep 11, 2005 | Palm Tungsten T3 Handheld
Exercise & Fitness Logo
Top Life Fitness Exercise & Fitness Experts
Vincent G
Vincent G
Craig Butler
Craig Butler
Android Man
Android Man
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
