After cleaning the inside of the printer it did not print properly (paper jam) and later stopped, made an information "temparature too law, off and on again". It did not work.
SOURCE: I have a samsung CLX 3175 FW printer. Paper jams
The limit switches are just flags that block or unblock photo sensors. Try blowing the printer out with some canned air, paper dust on these sensors is a common cause of these problems.
Testimonial: "Thanks very much, I'll try that - I'd like to think it was as simple as that! Kind regards Ray"
SOURCE: my samsung clx-3175 jams the
Hi! As a first course of action I strongly suggest that you clean the paper roller. The roller may be dirty causing the paper to jam. Please write back on the progress. Hope this helps and thank you for using FixYa!
SOURCE: Paper jam Samsung CLX 3175FW
I had the same issue, bought a bunch of sensors as they were only sold in lots, have some listed on ebay.
the proceedure is to remove the side covers, then the top cover and scanner assemblies an then the fuser, the sensor is then visible. not something that someone with no experience should really tackle.
if you decide to give it a go, see my listing in ebay listing number is 200520759089 or you can search by samsung jam fix
SOURCE: how do i clean a samsung clx 3175 color laser
You need to carefully vacuum out( do not blow in) all the loose toner. Then use cotton pads to clean up the residue that the vacuum does not get. Of course you have to take the drum out before you vacuum. You will see pickup rollers , clean them with a damp cloth with a dab of dish detergent. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays! Thanks, Joe
There is a optical lens on the top inside, use a clean cotton pad to go across it and clean it.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: clx-3175 laser printer always results in a paper
first remove the power and remove the cartridge cover and inspect for tiny piece of paper remove the piece of paper or you can use an mild air blower to flush it out for that first remove the toner and use the air blower and clean the inside of the printer if there is any tiny piece of paper the paper get jammed often
