Kyocera FS-1128MFP FS-1128MFP Multi-Function Printer with Prin Logo
A
Anonymous Posted on Jul 09, 2014
Error type: connect - Kyocera FS-1128MFP FS-1128MFP Multi-Function Printer with Prin
donovin mclain
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Kyocera Expert 210 Answers
  • Posted on Nov 25, 2014
donovin mclain
Kyocera Expert
Level 2:
New Friend:
Cheetah:
Answers
210
Questions
Helped
108207
Points
231
Smb scanning? check to make sure host ip is conrrect as well as long in info and path to folder /email make sure smtp server address is correct along with login info and try port 587 if its set on 25 comcast tends to block 25 for smtp scanning
What does error F:16 indicate?
It would be helpful to know tha make and model. Different manufacturers use the same code for different things. Can't tell from the picture (It looks a bit ike a Whirlpool)
Error: F16,
Machine: Washing machines & Washer Dryers,
Type: Standard,
Fault: Water level far too high. Check pressure switch, pressure hose (for blockage or disconection)also the pressure chamber for blockage
Error: F16,
Machine: Dishwasher,
Type: Bosch EXXCEL,
Fault: Door not closed. Check door is closing properly or door switch.
Error: F16,
Machine: Washing Machine,
Type: whirlpool (not every model),
Fault: Faulty control unit.Check wiring connections, replace unit.
Error: F16,
Type: Dyson CR01,
Fault: Motor fault.(Faulty triac).Check motor and associated wiring, check module and connections Faulty tacho. check tacho and associated wiring, chech module for loose or defective connections.
Error: F16,
Machine: Washing machine,
Type: Bosch WFP Series,
Fault: Rinse sensor is fault.(This error code will only show up in test mode).
I tri to connect internet error code 51330
Error code 51330 is trying to tell you that the Wii Wireless Adapter cannot connect to your wireless router. The most likely reason for this error is that the password you entered is not typed correctly, or that you forgot to type one in at all. Remember that security keys are always case sensitive.
Command error on epson 9600
Are you sure it is a 'command error' and not a 'communication error'. I could not find anything on a 'command error' but did find this on a 'communication error'.
Q: Why am I getting a communication error when I try to print?
A: Check the following if you are getting a communication error when printing:
Make sure the type of driver you installed matches the ink type in the printer. Verify the ink type by checking the part number on the ink cartridges.
Make sure the printer interface setting matches the connection type you're using. By default, the printer interface should be set to Auto, which supports all connection types.
Check the physical cable connection and make sure the cable is not be longer than 10 ft. You may want to replace the cable.
You may also get communication errors if the printer name is not set correctly. Contact EPSON at (888) 377-6611 or (562) 276-1305 to get instructions on how to verify this.
You might want to check to see if you have the current drivers for your printer and operating system; a new driver can be downloaded here.
Trust this is helpful.
Cant connect to my wireless router and the 192.168.01 url entered doesnt help none
Windows XP
  1. Verify Ethernet adapter in device manger.
    1. Click Start > Search > Type in ncpa.cpl and press Enter.
    2. Click System>Hardware > Device Manager
    3. Click Network Adapters
    4. Verify adapter present, enabled, and no error messages.
    5. If error reported refer to OEM regarding error receiving
  2. Open the Network Connections window.
    1. Click on Start > Run > Type in ncpa.cpl and click OK.
  3. Double-click on the Local Area Connection icon.
  4. Click the Support tab.
    1. Ensure that Address Type: says "Assigned by DHCP."
    2. Ensure that the IP address is valid.
    3. If both are correct, click the Repair button and then skip to Step 9.
  5. If it does not say "Assigned by DHCP" click the General tab and then click Properties.
  6. Select "Internet Protocol TCP/IP" and then click on the Properties button.
  7. Ensure that the radio buttons are marked as "Obtain an IP Address automatically" and "Obtain a DNS Server address automatically" and click OK.
  8. Click OK again to close out of the Local Area Connection properties.
    1. Restart the system if any changes were made to the configurations.
  9. Right-click on Local Area Connection and select Repair.
  10. If the repair fails because the system is unable to flush the ARP Cache, the Routing and Remote Access service will need to be stopped and set to disabled.
    1. Click Start>Run>Type services.msc >Click OK.
    2. Double-click on Routing and Remote Access.
    3. Click the Stop button.
    4. Set Startup Type to Disabled and click Apply, then OK.
    5. Restart system.
  11. If the Repair fails to renew the IP address, ensure that all firewalls are disabled and try again.
  12. If it still fails, reset the networking protocols.
    1. Click Start>Run>Type CMD and click OK.
    2. Type netsh int ip reset reset.log and press Enter.
    3. Type netsh int ip delete arpcache and press Enter.
    4. Type netsh winsock reset and press Enter. (SP 2 or later)
    5. Type ipconfig /flushdns and press Enter.
    6. Restart the system.
Windows Vista
    2. Click Hardware and Sound > Device Manager
  2. Open the manage Network Connections window.
  3. Right-click on Local Area Connection and select Properties.
  4. Uncheck Internet Protocol Version 6 (TCP/IPv6).
  5. Select "Internet Protocol Version 4 (TCP/IPv4)" and then click on the Properties button. (Do Not Uncheck Version 4).
  6. Ensure that the radio buttons are marked as "Obtain an IP Address automatically" and "Obtain a DNS Server address automatically" and click OK.
  7. Click OK again to close out of the Local Area Connection properties.
    1. Restart the system if any changes were made to the configurations, including unchecking TCP/IPv6.
  8. Right-click on Local Area Connection and select Diagnose.
  9. If Diagnose fails to renew the IP address, ensure that all firewalls are disabled and try again.
  10. If it fails again, choose to "Reset the Network Adapter."
  11. If it still fails, reset the networking protocols.
    1. Click Start>All Programs>Accessories.
    2. Right-click on Command Prompt and select "Run As Administrator"
    3. Type netsh int ip reset reset.log and press Enter.
    4. Type netsh int ip delete arpcache and press Enter.
    5. Type netsh winsock reset and press Enter.
    6. Type ipconfig /flushdns and press Enter.
    7. Restart the system.
Windows 7
I hope this helps
CAN NOT CONNECT TO THE INTERNET. KEEP GETTING AN ERROR MESSAGE
What type of error message are you getting?
Meanwhile, go to the command prompt (start-run: type in cmd and press enter) and type in
ping google.com
If you do not get a response from google, then u actually have no Internet connectivity.
But before we can really resolve this quickly, please let me know what the error message u're getting is. Then let me know the results of the PING TEST.
CAH
2helpful
Error type: Connect?? Can't scan.
Check your ip settings.. or if your scanning to file, make sure you have the directory path correct and have the right authentication credentials if its on a server..
I cant open anything it says there is error on page, plesae help. error HM undefined error Expected J
Cannot access or browse websites after being connected to Internet.
This problem is only due to the corrupted Winsock2. Solution is very simple ...just type a command at the command prompt
Type cmd in the RUN
type netsh then type winsock and then reset command at the command prompt
Restart your computer and Winsock2 shall be fixed.
2helpful
Wii Error Code 91010.
Error Code: 91010
Our experience shows that error messages within this range are typically caused by temporary network issues with the Nintendo Wi-Fi Connection. If there is a problem with the network, our technicians will work to get the service back up as soon as possible. Please retry your connection later.
If you are connecting to the Nintendo Wi-Fi Connection for the first time, or the problem has not resolved itself after a few hours, please review the following:
  1. Our servers may be trying to handle an unusually high amount of traffic (especially if you are trying to play online with a recently-released or popular game, or if there is a new Wii system update). Please wait a few hours and try the connection again later.
  2. How are you connecting online? The Nintendo Wi-Fi Connection is only compatible with Cable, DSL, and Fiber-optic internet connections. If you are connecting via Satellite, EV-DO (cellular), Dial-up, or other types of connections, then you should try to use an alternate type of connection. Contact your Internet Service Provider if you are not sure what type of internet connection you have.
  3. The error may be caused by a basic setting on the router that needs to be adjusted (such as the channel). Please review our general router troubleshooting.
2answers
Connecting to internet
http://www.wiierror.com/wii-error-51000.php
Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase the download speed.
4helpful
3answers
Error 52030 in internet connections
one option is try choosing a different type for your password...i've had the same error before and what i did was to change the password type e.g. from wpa aes-tkip to wpa-aes passphrase (this option will appear during your wii internet connection set-up as you would probably know by now) and everything right afer started to fall in place perfectly...my wii started connecting to my router and never had the same error code ever since.
Top Kyocera Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
