Electrical Supplies Logo
A
Anonymous Posted on Jul 09, 2014
Pramac s5000 instruction book - Pramac Electrical Supplies
Ngoro
Level 3:
Top Expert:
  • Master 3,523 Answers
  • Posted on Feb 05, 2021
Ngoro
Master
Level 3:
Top Expert:
Answers
3523
Questions
0
Helped
298451
Points
261655
Have no output power on my pramac s5000 . Motor starts fine, flip CBS on, and motor surges a second.
Disconnect all loads before turning on breaker. Add one load at a time. Do not exceed generator capacity.
Comment below for further assistance.
How to change oil in pramac gsw 50kw towable generator?
If you have a Yanmar engine...
There is a hose that is connected to the oil pan in place of the drain plug directly under the oil filter that will have an end cap. This hose is used to drain the oil into a waste container.
Download the service manual located at the address below and follow the instructions in the manual.
http://www.martindiesel.com/Documents/New%20TNV%20DIRECT%20Service.pdf
Hope this helps.
1helpful
Fuel shut valve detached from bottom off fuel tank where it appears to have been glued on. How to reattach?
most have a rubber grommet that goes in the hole in the bottom of the tank and the shut off valve goes in the center
I need a instruction book for this camera
Hello
You can download the requested manual HERE.
Kind regards
Andrea
2helpful
2answers
Fujipix S5000 screen is all white
I just started having the same problem with my S5000, also.
I have been given a camera Fuji FinePix S5000 without instruction
here is the link for download
It is a PDF file and you can print it.
Good luck
http://www.fuji.fi/documents/12/5000_manual.pdf
Downloading Usder Guide Book
hi you should be able to find this on the fuji website...marv 2
Top Pramac Electrical Supplies Experts
littlewheel
Ngoro
john h
Are you a Pramac Electrical Supply Expert? Answer questions, earn points and help others
