How do I replace the pulsation damper on the ABC pump of a 2007 SL550?
Actually, it can be replaced on the 2007. I own a mobile auto repair business and replaced the damper at my customer's home.
If you notice, there is not enough room to lift it straight out because of the head on the M273 V8. You will have to remove the belt and take out the bolts for the Tandem pump so you can tilt it enough. The front bolts are not that bad. There is a bolt holding the pump in place that you will need to get to from underneath. Once you have removed the bolts, you can move the pump far enough to unscrew the damper and take it off.
