Dewalt 7.2-18.0 Volt One Hour Charger Logo
A
Anonymous Posted on Jul 09, 2014
Diode D23 in De9116 charger - Dewalt 7.2-18.0 Volt One Hour Charger
Ahmet Snmez
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Nov 26, 2015
Ahmet Snmez
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2622
Points
7
D23 is a transient voltage suppressor. Code: 1.5KE51A
3 Related Answers
Anonymous
  • Posted on Jul 02, 2010
SOURCE: Diode D26 in De9116 charger
Ask for BD2003XR3 datasheet
puertobori
  • 7733 Answers
  • Posted on Nov 04, 2010
SOURCE: I think diode D23 is
Go to this LINK and find the part/diagram that can help you.
Please thumbs or post back,thanks
Anonymous
  • Posted on Sep 16, 2011
SOURCE: I have a dewalt de9116 charger and when a battery
I have tried pulling out almost all the transistors and checking it individually but all of them is all right.
Need resistance for diode d23 for DeWalt dw9116 charger
Diodes do not have a resistance. They have a forward bias current and a reverse voltage limit. There should be a number on the device for a google x-reference.
Apr 03, 2018 • Drills
1helpful
Charger for dewalt 18volt drill burned out a diode need to know what to replace it with to burned out to tell ??
I had to replace that on one of mine. It is not a regular diode. P6KE51A Transient Voltage Suppression (TVS) Diode. That is the part # on the USA model. A European model may use different #. 8645a6dd-c755-4fe7-a00b-699ca51bc6af.jpg
Polarity protection diode d23 d28 classic
d-23,it should be the only diode in the area of the red and black wires
My DE9116 battery charger keeps flashing very fast and not charging, any suggestons? I have changed the fuse!
IF is doing that without battery on it maybe charger is bad but if flashing that way when you put the battery could be the battery hope this helps!
2helpful
I think diode D23 is defect, but I cannot see any number on it. Please advise
I HAVE DEWALT CHARGER DE9116.ITS OUT PUT VOLTAGE WITH OUT LOAD IS 51 VOLT.AND WITH LOAD IS 15 VOLT.THE BAATERIES BECOME VERY HOT WHILE CHARGING
check output voltage on charger label most chargers are not regulated so if it says 18 volt output it may put out 24 volts but if its putting out 51 volts it may have a short batteries will get warm but not hot replace charger
2answers
I have a dewalt de9116 charger and when a battery is put in it flashes constantly even a new battery. Is the charger defunct?
I would say tee charger is no good. The only internal component is a circuit board so it is not worth trying to repair it/get spares as it will cost the same as replacing the charger.
Cobra 29 NW ST No Sound, litesup, keys up, needle swings
It sounds like it may have been hooked up backwards when hooked up to the battery charger. If so it probably blew the polarity diode (D23) (1N4004) and with no sound it probably blew the audio IC (TA7222AP) mounted to the case of the radio. Also look at all of the large capacitors and make sure that the tops are not swollen or busted open if so they need replaced also.
1helpful
Cobra 29ltd classic : no rx / tx
D23 is the reverse protection diode and it shorting is the primary reason your fuse blew. As you posted, power was applied in reverse, hence other components would also fail. Pls check:
1. D22 - 9.1V Zener Diode
2. TR23 (2SC1096) 9 Volts regulator
3. D19 - 5.1 Zener Diode
4. IC4 (TA7222) - Audio Amp
5. TR14 (2SC2029B/10) - Finals
6. TR15 (2SC2028B/20) - Driver
7. Most capacitors over 220uF (like C123, C114 & C112)
Hope that this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Top Dewalt Drills Experts
Sean Wright
Sean Wright
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
