SOURCE: need a manual for a goodman
An owners manual will only tell you when to and not to operate the out door ac. And give you some maintenance tips.
A technical manual will have a wire diagram maybe a mollier diagram or other diagram for recommended pressures and temperatures and maybe some trouble shooting tips (but not likely) on things like checking power in and thermostat settings.
If you need anything in particular please be specific about your trouble and post it. If you post back with more trouble I'll try to help you more.
If this helps you please rate me as high as possible.
Thank you for using fix ya and GOOD LUCK!
SOURCE: I have a Goodman air conditioner. My outside unit
If you are sure of the power then ya have a control problem thermostat set correctly? could be open low pressure switch I would call for service. Tom
SOURCE: my air conditioner air handler humsbut moter does
either bad motor ....or.... if you are lucky a bad run capacitor. you will need some sort of capacitor checker and multimeter to diagnose it further.
