Bosch SHU9915UC Dishwasher Logo
A
Anonymous Posted on Jul 09, 2014
Bosch shu9915uc not cleaning dishes - Bosch SHU9915UC Dishwasher
2 Related Answers
Anonymous
  • 128 Answers
  • Posted on Jan 18, 2008
SOURCE: Bosch SHU9915uc/u12 making noise
Try out this site. Hope this helps :)
http://servicefunctions.bosch.com/user/contactdealer/index.asp?country=wo&lang=en&app=contact&gb=&option1=&option2=&option3=&email=&opener=http%3A//www.bosch.com/content/language2/html/index.htm%23%23%23
Anonymous
  • 2605 Answers
  • Posted on Jan 10, 2011
SOURCE: bosch model SHU9915UC dish whasher
Welcome to FixYa.
Based on your description, "water feed will not turn off"...the issue is not likely the control, but rather with the inlet/water valve.
**To remedy this you will need to check and likely replace the valve**
This is what to look for..i.e.
As long as your model number is indeed correct, this info below will be accurate.
Original part is # 425458. It usually retails for about $20 - $30USD at places such as "searspartsdirect.com" "repairclinic.com" to name a couple, if needed. They may be available at your local brick & mortar parts depot/vendors.
**Before attempting to repair the unit please turn off the power and the water supply to the dishwasher...safety first**
If you remove the lower kick plate/toe panel, you will see the inlet valve to your left...
i.e.
Replacing it or to check for debris in the filter/screen at the inlet is pretty straight forward. Here`s how...
1) undo the water line. ( here you can visually inspect the screen in the valve...if nothing noted, you'll likely need to replace it as follows )
2) Remove the two #20 torx screws fastening it in place.
3) the feed tube to the machine at the back of the valve and swap it with the new one.
and
Once the new one is in or it's all clear you should be good to go.
Let me know if you need any further assistance, otherwise good luck.
Thanks for visiting FixYa.
Regards,
Macmarkus :)
I think the rinse cycle is not working on my Bosh dishwasher. It is leaving a soap residue on the dishes.
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Cloudy dishes coming out after wash
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
1helpful
Dishes do not come clean and there is cloudiness on glasses
Hello and welcome to Fixya. There are several factors which influence how your Bosch perform's. Saying that brings me to a point I have to ask a few questions. 1) How long have you had the unit...when did you buy it ? 2) do the dishes always appear dry when the cycle completes ? 3) How long does the unit take to complete a "normal" wash cycle ? 4) Do you have adequate hot water going to the unit ? Let me know as much as possible and I should be able to help. I will watch for your response. Macmarkus :)
2helpful
My Bosch doesn't clean and leaves a lot of particulate matter on the dishes-- that seems to be coming from somewhere other than the dishwasher????
You need to clean it with either white vinegar, or either of the two products that have citric acid in them. (Dishwasher Magic or Lemi Shine). I like the Lemi Shine the best.
My Bosch dishwasher leaves soap on the dishes and glasses. I wind up rinsing and drying everything over again by hand.
It looks like rinsing is not proper inside the chamber.
Check your water inlet. Clean the strainer attched to it at the machine end.
Maytag performa dishwasher PDBL390AWB - dirty dishes
The problem is hard water. Go to www.dishwasherfilter.com and get their new product. It filters the water and takes out the hard minerals that cause spots and clog dishwashers. It is very affordable and has a money back guarantee.
Drain was clogged and the dishwasher overflowed. It's a 10yr old Bosch dishwasher. Now water won't flow into the dishwasher but it runs through the cycle and dishes arent clean.
Probably the aquastop (if you have one). We have a similar problem after our owerflow. The dishwasher is starting and running through the programs but no water is coming.
Clogged dishwasher drain?
clean the filter, check the water inlet and outlets for blockages
1helpful
Specks of "sand-like" food on my dishes; water not draining
I bought a replacement filter and that dramatically cut down on the amount of "specs." Now there are only a few in some of the glasses. I also cleaned out the drain underneath the screen, there were peas and corn in there, I just used a shop vac to **** them out. Seems to be much better now, I think a good inside cleaning of the washer will help out too. Hope this helps...
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
