Check an make sure your fuse is tight the one coming off the battery for your amp if that dosnt work try grounding your amp to the battery to make sure the ground is good
You can backup all your important data to your PC, & then format both phone & memory card. Or try to delete application files, using xplore delete files all at once from folders "system\programs" and "system\recogs then........
First format your mmc with pc computer using card reader.And then format/reset your cell.Don't insert mmc to cellphone until you formated both memory.For nokia s60 try insert code *#7370# to format it.
You can also delete it manually with lcg xplore
1. Kill the processes qwpuec.exe
2. With lcg xplore find and mark the virus at
c:/system/apps/qwpuec.exe and qwpuec.sis
c:/system/data/qwpuec.exe
c:/recogs/qwpu.mdl
e:/system/apps/qwpuec.exe
e:/system/recogs/qwpu.mdl
3. Delete (if it can't be deleted,change its attribute 1st
Ive done some research and i haven't found any conclusive ending however the best i can do is tell you the round about RMS which is approx 200 to 150 unbridged.
