SOURCE: hp laserjet 2420 printer printing completely black pages
remanufactured / compatible toner? sounds like defects to me. try OEM, or another supplier
SOURCE: hp laserjet must manually push button to print
Please print a configuration page from the control panel of the printer
- Menu > Information menu > print configuration.
- Check for paper handling details.
Following setting should reflect.
Tray 1: Any size / Any Type
Tray 2: A4 size / Plain Type
If the above settings are not reflecting in the configuration page, please change accordingly by browsing on the control panel of the printer to:
Paper Handling Menu >
Tray 1 Size: Any
Tray 1 Type: Any
Tray 2 Size: A4
Tray 2 Type: Plain
Let me know if that helps to solve the issue.
Regards,
Nikhil.
SOURCE: hp laserjet 3600 PCL XL error when printing a PDF
This is a known issue with 'host-based' printers like the 3600. You need the PCL5 driver, which this printer will not work with. You need a different printer, such as the HP 3520.
This page will explain it all.
SOURCE: HP Laserjet 2420 printer says processing job but
You will have to follow the some steps for it.
Now it should be work for you.
SOURCE: how to connect to network printer hp laserjet 2015 PCL5
I cannot connect to hp laserjet 2015 PCL5. wia network...
im
using 64 bit windows 7, and tell me that Windows cant find a driver for HP.........i install driver and nothing........
