Click the bottom left button and scroll through 'til you get to the time function. Hold down the top left button ad the hour will advance - let go. Select bottom left again and the time is set
I had the same problem with the watch my wife bought me. On the mode make sure it doesn;t say T2 in the top right hand corner. if it does you are in the wrong mode. Hit the mode button until it shows the day of the week highlighted and a date and then go through the normal time set procedures. That worked for me.
You can easily change the time of your Timex watch by following the steps below.
1. With the time and date showing, press the top left button.
2. Press the right top button (this sets seconds).
3. Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm).
4. Press the bottom left button, minutes flash. Press the top right button until correct minutes.
5. Press the bottom left button, month flashes. Press the top right button until correct.
6. Press bottom left button, date flashes. Press the top right button until correct.
7. Press bottom left button, day flashes. Press right top button until correct.
8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
To turn off the chime and alarm: Press bottom left until in the alarm screen. Then press the top right button repeatedly until the CHIME or CH symbol is gone and/or ALARM or ALM to disappear, then press the bottom left button to go back to main time.
To set the digital time and date on your Timex, please follow the steps below.
Timex Digital Watch
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Thank you for contacting FixYa. <br />
You can find the manual here!<br />
<a href="http://www.timex.com/info/Product_Instruction_Guides_Downloads">http://www.timex.com/info/Product_Instruction_Guides_Downloads</a><br />
Best regards!
I bought this for my son and he has been living with it for 4 months, and hour and ten min. off ! I just want to set the time, and I'm at the top of the world, no radio shack down the road. Turn right at the polar bear.
Time jumps ahead l hour today, how do i adjust my 1440 sports watch?
I am trying to reset the time on a timex 440 watch. Please help
how to set the time?
I do not understand how to set the time on my son's Timex 440 Wrist Watch
