SOURCE: GENERAL ERROR IN EPSON STYLUS T10
Probably the waste ink tank is full.Try to do this:
First of all download http://www.mediafire.com/?hzxbdhkzxv9.Extract to your C drive. Run indoreset.bat, then follow the instructions.
After that right click AdjProg and select properties. Go to compatibility and select Windows XP.
Click OK at the bottom then right Click AdjProg and select run as administrator (if you have this
option). When working accept the agreement and go to
1. Particular adjustment mode,
2. Then waste ink pad counter,
3. Click Check
4. Tick both boxes.
5. Then initialization.
6. Then it's done.
SOURCE: Epson Stylus Photo P50 - flashing alternate amber
This is an identical issue to the one reported here:
http://www.fixya.com/support/t13406382-epson_p50_not_respond_blinking_lights
As per the information provided in my solution you can either get the printer serviced or fit an external waste kit and reset the waste counter yourself.
