iRobot 4150 Roomba Vacuum Logo
A
Anonymous Posted on Jul 09, 2014
4150 Roomba charger - iRobot 4150 Roomba Vacuum
1 Related Answer
Anonymous
  • 27 Answers
  • Posted on Aug 07, 2010
SOURCE: My roomba 4150 is running very slow. It is fully
may need to clean inside.the wheels pick up trash and deposit it on and near motors.also try to take ends of roller brushes off and clean hair ect.
Roomba repair
What seemed to be the problem?
The brushes o longer turn in my roomba
Try removing brushes, cleaning thoroughly removing yellow tips if there is any and removing hairs, re install brushes and turn manually about 20 turns and re try
The romba 4150 vacuum is not getting charged and red indicator light is constantly blinking. what is going bad charger or the batteies
Seems like a bad battery. The Roomba detects that there is a battery present so the battery must be at fault.
1helpful
My irobot (Roomba)is only working for 10 mins then
It should take about 6 hrs to charge. I had the same problem and reset the charging circuit. 1) Charge it until the green light comes on. 2) Unplug and pull battery out. 3) hold down the power on button 15-30 seconds. 4.) Put the battery back in, plug in the charger (direct - not through the dock) and charge for 72 hrs. Then, run at Max clean until the "I'm dead" tune plays.
I have a iRobot 4150 and have recently experiencing performance issues with the vacuum. Recently, it started stopping about a minute after you turn it on. I thought maybe the battery was the issue, but I...
Yes, a common issue with the cleaning head module, chm. You will need to diassemble the Roomba and remove all debris from the CHM. Also take a look in its gear box.
My roomba keeps telling me "error and to clean the brushes. I have cleaned the brushes and when I turn the roomba back on it keeps clicking underneath the roomba. I'm not sure what else to do.
I had the identical problem. I cleaned the brush but the problem persisted. I then put in a new brush that was provided in the box and the problem vanished. I have since used the cleaning tool on the old brush and will try and reinstall it to see if my cleaning worked. In any case a new brush will do the job.
Tim B
The wall charger for irobot roomba needs replacing how do i get hold of a new one
Here you are....there are a BAZILLION of them!
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=roomba+wall+charger&_sacat=See-All-Categories
Running backwards in circles.
If your Roomba's speaker isn't working, you need a new Roomba regardless. Give a call to customer support (877-855-8593) and they'll help you out.
2helpful
3answers
ROOMBA 415
It could be the power button itself. If you have a Roomba remote, try using that to power on the robot.
Top iRobot Vacuums Experts
Oliver Street
NOEL
NOEL
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
