Yes, the bladder of a Sportsstuff Speedzone 2 tube can be removed to fix a slow leak. To do this, you will need to locate the valve that inflates the bladder and remove it from the tube. Once the valve is removed, you can carefully pull the bladder out of the tube and locate the source of the leak. Depending on the size and location of the leak, you may be able to patch it with a repair kit or you may need to replace the entire bladder.
It is important to note that removing and repairing or replacing the bladder can be a difficult and time-consuming process. If you are not comfortable doing this yourself, it would be best for you to take your tube to a professional repair shop.
If this is a natural rubber tube,the good old bike patch kit will do.If it is a vinyl tube,there is a type A or type B.(Different chemical makeups in different types of vinyl will only adhere to the same type).I don't know how to tell which type of vinyl is which,so get one of each type(at a sports eqipment store).If the first one doesn't adhere,you should be able to clean it off and try the other kind.
Cynthia, I have the same tube and looked around and found nothing... but luckily we were within 90 day warranty period and Kwik Tech sent me a replacement air bladder. If you're not so lucky you'll have to buy the whole thing again. But if you cover is in good shape you could always sell it on ebay and help offset the cost of the new tube. I would be willing to bid on it... my cover is getting worn. robloch at hotmail dot com Hope this helps.
The pump should only run if you are using water. If you have a leak it will cycle on and off. If it only cycling fast when you're using water, you may need an expansion tank, sometimes referred to as a bladder tank for newer style. If you have a "bladder" tank , the bladder may be leaking and lost it's air charge. This bladder will have an initial air charge, and when the pump runs it will compress the bladder even further. When the pump shuts off the bladder is compressed. When you begin to use water, mainly low flow like one faucet, the bladder will begin to expand expelling the water from the tank until the pressure drops below that of the pump pressure switch. This makes the pump start and stop fewer times.
Unlock doors
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times Put key in to IGN position Push valet (black button) one time and release Push and hold valet button Push either lock or unlock on viper remote Key out of IGN Test unit The horn or siren may sound afterwards to indicate SUCCESS!!!!!!
