Neato XV11 Vacuum Logo
A
Anonymous Posted on Jul 09, 2014
Solid amber light and will not turn on - Neato XV11 Vacuum
2answers
I have a new Dyson V8 Absolute When I try to charge it nothing happens. When I pull the trigger I have one flashing blue light. HELP
not trying to be a smart a** but which of the two do you have?
1. A flashing blue light indicates that the battery is running low on charge.
2. A fast flashing blue light indicates no power or a temporary fault (e.g. check filter or for blockages).
FYI....A solid blue light indicates that the battery is charging. No light indicates the battery is fully charged. A solid amber light indicates that the battery is not charging due to a temporary fault (e.g. too hot/cold). A flashing red light indicates that there is a fault, call the Dyson Helpline.
Best to you.
1helpful
What are these 2 blinking lights on my irobot roomba?
"The Charge Indicator Light is located immediately to the right of the power button on Roomba Red and Roomba (sage). On Roomba Discovery and Discovery SE, the Charge Indicator Light is incorporated into the power button. Please refer to the table below to determine what the Charge Indicator Light is telling you.
* Pulsing Amber - Charging
* Green - Fully Charged
* Amber - Partially Discharged
* Red - Almost Fully Discharged
* Flashing Red - Fully Discharged"
At the end of a cleaning mission, Roomba will tell you if it has successfully completed it's mission or not:
GREEN = MISSION COMPLETE
YELLOW = MISSION ABANDONED (Check robot's brushes, etc.)
YELLOW RED POWER BUTTON = BATTERY DEPLETED (Scheduler Models)
RED YELLOW POWER BUTTON = BATTERY DEPLETED (Discovery Models)
number of beeps after ?uh-oh? :
No beeps: A wheel is stuck or is not touching the ground. Pick up the robot, place it down securely on the floor and touch the clean button to restart the cycle.
1 beep: The main brushes cannot turn. Turn over Roomba and remove the brush guard by pushing the two yellow tabs. Remove the brushes, clear any obstructions, and replace them again.
2 beeps: The side brush cannot turn. Turn over Roomba. Look to see if something is wrapped around the side brush. Remove the side brush with a screw driver and check for string or hair that may be wrapped around it.
3 beeps: The vacuum cannot run Remove and empty Roomba?s bin.
4 beeps: A wheel motor cannot run Your Roomba may be stuck or something may be wrapped around a wheel. Look for something wrapped around the wheels. Push them in and out and make sure they turn easily.
5 beeps: The cliff sensors have failed or are blocked. Turn over Roomba and clear any debris that might be caught underneath the front bumper in the cliff sensors. You can also use compressed air to clean them out.
6 beeps: Wheel obstruction or robot attempting to drive over an obstacle. Turn over Roomba and remove any obstructions that prevent the wheels from seating all the way up into Roomba?s body. Also, remove any obstacles that Roomba could drive over.
7 or 8 beeps: Not applicable Roomba?s beep codes do not include 7 or 8 beeps. If you are getting an error with 7 or 8 beeps, try counting again or contact iRobot Customer Care.
9 beeps: Sensor error Please contact iRobot Customer Care.
10 beeps: Roomba is stuck Pick up Roomba and start it again somewhere else. Use a virtual wall or other barrier to keep Roomba away from the
place it got stuck.
Your Roomba may be experiencing an issue where the battery is deeply discharged and may need to charge longer than the standard 3 hours. (or 7 hours if you have a standard charger)
Even with the charging light showing green (this indicates a fully charged battery) the robot is still charging. If your Roomba exhibits behavior where it charges for a short time then runs for a short time you will need to do the following.
1. Plug the charger into Roomba (if you have a home base be sure to plug directly into Roomba instead of using the home base, this will ensure the robot's charging cycle is not interrupted.)
2. After the Roomba's charging indicator goes to solid green please keep the Roomba on the charger for an additional 72 hours. (3 days)
3. After the 72 hours (3 days) has passed, turn your Roomba on and begin a normal cleaning cycle. If this works successfully it may take several uses for the battery to get back up to the performance it once had.
If this does not correct the problem, please call customer support at 877-855-8593
Nov 22, 2012 • Vacuums
2helpful
Kenmore InteliClean 116.35923502 Two, I believe unrelated, problems. 1) The InteliClean sensor lights stay amber and red even when the machine is in the upright position and the suction line is...
I had the same problem with the amber inteliclean light continually on. I found the problem to be in the plastic housing that connects the suction hose to the back of the upright section. You have to remove three screws and gently pull the hose housing off the vacuum. Inside I found a hairy clump that was caught on the inside of the hose. The optical "dirt sensor" is just inside the fitting on the upright section. When dirt or other stuff blocks the optical path of the sensors, the amber light will illuminate. My vacuum had an uneven cut on the hose which caused a snag point for hair, dirt and debris. Once this was removed, the vacuum worked like new.
Regarding the roller, this unit has an integrated motor in the roller. I would guess that you will need to take it apart, and hopefully only clean it up. If you need bearings, that will likely be expensive.
9helpful
2answers
Status light is red, why? I have a Roomba Discovery.
Hi.
If the red light is solid, that means that the Roomba is near to full discharge. If the light is flashing red, then the Roomba is completely out of charge.
If the Roomba is fully charged, then there may be a fault.
Here full list of light codes:
Here manual
See also
Roomba DISCOVERY MODELS' DIAGNOSTIC TESTS
May 24, 2010 • Vacuums
4helpful
3answers
Help
Same thing happened to me, I called the company, and they told me to remove the battery, press the on button for 5 seconds, which clears the system, replace the battery and do a long charge 12 hours. I'm in the process of doing that now.
Top Neato Vacuums Experts
john h
Are you a Neato Vacuum Expert? Answer questions, earn points and help others
