SOURCE: Camera will not work with sd card
Had the same problem, blew out the card slot with air and fixed it. Apparently poor contact points with the card.
SOURCE: camera screen said SD card is locked when I installed an SD card
#1) On my camera if there was a picture that got stored in the internal memory it would not reconize the sd card nor store the pictures on the sd card. I would have to take the sd card out and delete the pictures in the internal memory and then reinsert the sd card.
#2) Some how or other the files that were on the sd card would get scrambled on the sd card when I would try to erase them. I would have to reformat the sd card back to a "fat" format before it would work again.
SOURCE: moultrie d40 locks up when I put the sd card in???
make sure card lock switch is forward toward contact strips fully.
SOURCE: SD card Locked
I have the same issue . . . tried new card, older card, 4 different cards, turned off camera, took out battery. I'm bummed.
SOURCE: The camera worked for two
It's probably the small ffc(ribbon cable) connections from control panel to main board...remove top to access control panel;remove 5? screws and CAREFULLY lift control panel from camera...ribbon cable is obvious...it connects at both ends to zif(zero insertion force) connectors...EXTREME CARE HERE...the small brown part lifts to remove pressure to cable and cable can be GENTLY removed...try re-inserting cable CAREFULLY to align conductors with contacts.
