Under normal operating conditions, the internal
temperature of the freezer will ensure the longterm
conservation of the stored food.
When such temperature rises above a certain
level (-12 °C), the appliance will trigger an
acoustic and light alarm. The light alarm is a
blink red light (Red Alarm Indicator Light), while
the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing
the Acoustic Signal Stop Switch once.
When switching on the freezer for the first
time, the Red Alarm Indicator Light will
blink until the internal temperature has reached
a level required for the safe conservation of frozen
food.
Dado
SOURCE: the red light on the bottom of the freezer is off.
check your manual it will state what why its flashing.sound like its getting to hot, might be to near the wall and not getting enough air at the back.adrian,,,,
SOURCE: POWER LIGHT FLASHES ON / OFF
You need to install or change the battery for the power out freezer alarm. Mine was just doing the same thing. I looked on the web for the answer and couldn't find it. Opened the door to look for the model number and there was the diagram for the light flashing codes. Mine's battery compartment is in the grill on the bottom (right below the door) on the left side. Takes a 9v battery. I had a power outage recently and it must have killed the battery after beeping for several hours.
SOURCE: why has my freezer stoped freezing. it is cold
The defrost heat element has failed or the fan unit has failed, either way it is easly diognosed and not too costly if you pick the right repairer.
If you turn the unit off for 2 days and defrost it total, then turn it back on, should work fine for 4-5 days then return to problem again, confirming my report, you can then tell repairer you are not stupid and hence, not get ripped off.....Russ
