Avaya 5400 Series 5410 Phone Logo
A
Anonymous Posted on Jul 08, 2014
Changing the name displayed on a 5410 telephone
1 Related Answer
Christopher
  • 105 Answers
  • Posted on Dec 01, 2013
SOURCE: How do I log into
Try to look up for a solution in user manual.
Change the display name?
Administering a 1400 Series Digital Deskphone
Perform the following steps for each 1400 Series Digital Deskphone:
1. Log into the Avaya Aura Communication Manager administration interface.
2. Perform one of the following steps:
? If you are adding a new extension and want to assign a specific extension number, use
the add station nnnn command, where nnnn is the new extension you want to assign.
? If you are adding a new extension and want to assign the next available extension
number, use the add station next command.
? If you are installing the 1400 Series Digital Deskphone at an existing extension, use the
change station nnnn command, where nnnn is the existing extension you want to
modify.
The Station screen appears.
3. Perform one of the following steps:
? If you are administering a 1408 telephone, type 2410 in the Type field.
? If you are administering a 1416 telephone, type 2420 in the Type field.
4. In the Port field, type the port address.
5. In the Name field, type the name to associate with this telephone. Administering 1400 Series Digital Deskphones
20 Avaya 1400 Series Digital Deskphones Installation and Maintenance Guide
6. Configure the remaining fields on the Station screen pages. Keep in mind the following
information:
? If you are administering a 1408 telephone, the first eight call appearance/feature buttons
displayed on the Station screen are administered on the 1408 telephone. (Since the 1408
telephone is aliased as a 2410 telephone, the Station screen displays 10 call
appearance/feature buttons.) The remaining buttons displayed on the Station screen are
not administered.
? If you are administering a 1416 telephone, the first 16 call appearance/feature buttons
displayed on the Station screen are administered on the 1416 telephone. (Since the 1416
telephone is aliased as a 2420 telephone, the Station screen displays 20 call
not administered.
? If you are administering a 1416 telephone with a DBM32 Button module, the first 16 call
appearance/feature buttons displayed on the Station screen are administered on the
1416 telephone. The remaining eight call appearance/feature buttons displayed on the
Station screen are administered on the first eight buttons of the DBM32 Button module.
The 24 buttons of the EU24 expansion module displayed on the Station screen are
administered for the remaining 24 buttons of the DBM32 Button module.
For more information about administration and features, see:
- Administering Avaya Auraâ„¢ Communication Manager, Document Number 03-300509
- Avaya Auraâ„¢ Communication Manager Feature Description and Implementation,
Document Number 555-245-205
- Avaya Auraâ„¢ Communication Manager Screen Reference, Document Number
03-602878
7. When finished administering this extension, save your changes.
Online Virus Removal 39 99 Online Virus Removal and Online PC Help
How to change the Extension Name??
If this is on an IP 500, then you will need to access manager and change teh user name.
2answers
How do I log into the manager to reset display name & time & date on the Avaya 5410?
If you dont know, you wont do any good by logging into manager, as you wont know where to go in programming.
Call in someone who knows what to do, as you could do detrimental damage to the system by not knowing what you are doing.
1helpful
How do you change the main display name on a Panasonic KX-T7453?
hello,
enter the menu of your phone, go to profile choose the profile you want and personalize it.
when personalizing change the name of the profile to the you want and activate the profile.
i am sure it will display your name.
thanks for using our website.
2answers
2helpful
5410 i want to change the name shown on the screen. how do i do this?
You will need to login to Manager and change it, that is the only way.
6helpful
How do i change the time on the avaya 5410 handset There is a feature code i have used before but cant remember where i wrote it down....... doh ! pls help!!!!!
  1. Press feature +(00)+(left intercom)+(left intercom)+#103 at extension 10 or 11.
  2. Enter a new time in 24-hour notation. For example, to set the time to 2:15 p.m., press 1415.
    A display similar to the following appears:
    System Time
    Data 1415
    This time appears on system display phones as 2:15 p.
  3. Select another procedure, or exit programming mode.
1helpful
Diverting incoming calls to another office
You have posted this question under the Panasonic system, but have mentioned the Avaya IP Office 5410. I can't help you with that.
However, for the "other user" that has the same problem, if you're trying to forward calls directed to your extension, you can forward them to any outside telephone number by using the Call Forward/Do Not Disturb (FWD/DND) button. The code numbers depend on your telephone system (the KX-T7633 can be used on multiple systems), and how your system was programmed by your installer, so I can't describe the exact procedure. Also, your extension may have been blocked from using this feature by your installer.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Top Avaya Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
