This is one of the most common garment steamer myths that people have held countless people back. Yes, chemicals will be require only if you intend to dry clean your clothes garment with a garment steamer. It is not a requirement for normal usage of the unit. Normal usage here refers to Travel Steamers for Clothes , fabric, upholstery, drapes, bedding and even households items such as table cloth.
You have a build up of water In the hose. Sometimes happens because the hose is too low to the ground. Try stretching the hose up and tap it and the water should travel back down the hose.
Another reason could be that you are using too much steam for that particular fabric.
ensure that your iron temprature is high enough to generate steam. if ironing delicate cloth ensure your steam option is switched off. if your iron has a filler cap or water container ensure they are fitted securely. water dripping usually when the iron is too cold to turn it to steam or you have a leak somwhere.
