Belkin (F5D7230-4) Router (587009) Logo
A
Anonymous Posted on Jul 09, 2014
How to I unlock the Belkin Router in the settings on my ipad?
5 Related Answers
Anonymous
  • 48 Answers
  • Posted on Sep 26, 2010
SOURCE: just setup my Belkin router and I cant get a
>>>>Connect any of the computer to the router using a cable
>>>>Open the internet explorer page and in the address bar enter the numbers 192.168.2.1
>>>>On your left hand side you will be able to see Firewall
>>>>Click on firewall
>>>>It will ask for the password
>>>>Leave the password and click submit
>>>>Disbale the firewall
>>>>Click on apply changes
THANKS....
With Regards......
Vaishu
Anonymous
  • 10406 Answers
  • Posted on Jul 30, 2011
SOURCE: G + MIMO Wireless Belkin Router - I cannot connect
Did you configure the router, to select:
1. SSID, the "name" of your network;
2. encryption-level. Hint: use 'WPA' or 'WPA2'.
3. password to your network.
If so, then enter the SSID/password on the iPad, to connect to your network.
Tom Marvolo
Rakesh Warrier
  • 708 Answers
  • Posted on Aug 18, 2011
SOURCE: trying to connect my ipad
Before you start :
Make Sure the Wireless Switch on your Computer is turned Off (If you are using a laptop to connect to the router )
Make sure that the Light on the Router is Solid Green
Step 1 : connect a computer to the router (Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 in the address bar of Internet Explorer
Step 3 : Once you are at the router setup .. on the left side underneath Wireless you can find Wi-Fi Protected Setup
Click it
Step 4 : If it is asking for a password .. leave the password field blank and click submit
Step 5 : Disable Wi Fi Protected Setup and click apply changes
Step 6 : Now on the left under wireless click Security
Step 7 : If it is asking for a password .. leave the password field blank and click submit
Step 8 : Change the Security mode to WPA-PSK (you can also choose WPA-2 but sometimes it doesnt work )
Step 9 : Type a password (8 Characters , It is Case Sensitive)
Step 10: Click apply Changes
Step 11: On the left , Under Wireless Click Channel and SSiD
Step 12: Change the SSiD to a Different name , Change the Wireless Channel to 11
Step 13:Click Apply Changes
Turn On the Wireless Switch on the Computer (If you are using a Laptop to Connect between router)
Now try to Connect to this new network on both your wireless Computers and Ipad
Let Me Know if it Works
Shaun Norden
  • 39 Answers
  • Posted on Aug 30, 2011
SOURCE: How do you set up
Your iPAd should see your wireless network like other devices do. Does your iPad not prompt you to connect to your home network? If it does you should enter your wireless pass key manually on your iPad.
Testimonial: "Bravo...you're my hero! Many thanks. "
Anonymous
  • Posted on Dec 10, 2011
SOURCE: how do i connect ipad to belkin wireless router
..just look for your network name or ssid .. on the ipad.. if it will ask you for a password just type in your network key..
My belkin wireless light is not on i can only get internet on my desktop but not on my ipad how do I fix this
If the wireless light is not turned in the router itself, then there might be some settings inside the router itself where the wireless is inactive, switch it on. If ur unable to do so, call up the belkin guys to check the settings. But remember before you reset the router remember the ISP settings, if you reset the router u have to reconfigure it again.
Cannot locate password on my router model F5D8635--4vI
Reset the Belkin to default settings and reconfigure SSID and Security Key(password). User manual can be found here: http://www.belkin.com/support/dl/pm00781ea-usermanual_uk.pdf
Wireless not working
To reset the Belkin back to the default settings -
Press and hold the pinhole RESET button at the back of the router and then power for at least 15 secs. Then release the RESET button.
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Can't connect my Belkin F5D7234-4 v4 to my ipad
This link is for Iphone repair, It solved some of my Ipad problems. Hope it works out for you
How do i connect ipad to belkin wireless router
1helpful
How do you set up a secured home router to an iPad2? Having a problem accessing my Belkin router with my iPad2. The iPad keeps asking me for a password which I don't ever recall setting up. There is...
G + MIMO Wireless Belkin Router - I cannot connect to the internet with my iPad. It will not accept the password to my network at home. How do I connect my iPad to my home network?
2answers
Ive connected my belkin device to may desktop. Now im trying to connect my ipad to my modem or the belkin..but getting no where lol Ipad finds the modem but say 'unable to join the network'. Any ideas...
which belkin device have you connected to your desktop? The ipad will be looking for a wireless network to connect to. So you will need a wireless router to allow it to connect, also the modems ethernet cable needs to plugged into the wireless router and IF you have the modem connected directly to the pc to allow it to connect to the internet , then you need to connect a lead FROM the router to the PC
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
