Dell 926 Photo all in one Inkjet Printer - a few lines on color printouts are irregular. Black and white print jobs do not have this irregularity. We only use Dell cartridges. Does this machine need to be cleaned?
SOURCE: Dell Photo 926 ink cartridges holsters won't show up
Contact the dell chat suport line on the dell.com website they are good at fixing probles even if they have to seend someone out or have you seend it in.
SOURCE: Dell 926 won't recognize new color cartridge
Try this...shut down the printer. Insert new cartridge, let the printer cycle out with new cartridge. then reboot the computer. This should solve the problem. The cache in the printer will not cycle out. It wants to see the printer as a new entity
SOURCE: My Dell Photo 926 stopped printing in color.
hi ,
if u can make a copy in color , rest assure ,nothing wrong with the printer .
it s only needs a setting change to be done .
is your pc running on xp r vista ?>
if xp : click start-->run-->type control printers --> your 926 printer should be displayed -->right click on printer icon and choose preferances-->..click on advanced option --more options --see if print color image in black and white is checked ? if so uncheck it
if vista : click start ---the cursor would flash on "start search "...typre printers and press enter key ...then ..your 926 printer should be displayed -->right click on printer icon
uncheck it
SOURCE: dell 926 photo printer will not print black ink.
Nope, not the cartridge...swapped out known good cartridge from our other Dell 926, still the same problem...printer will not print black...both carts work fine in other Dell 926
