SOURCE: Gas Dryer
HI thanks for your question. the problem is with the coils on the gas valve. one has failed. they come in a pack of 2 replace the coils. thanks the appliance doc. please rate my answer. thanks.
SOURCE: How do I open the dryer to replace a loose belt?
there are 2 clips holding down the main top, approx, 3-4 inches in form each side of the main top where it meets the front panel. With a flat blade screw driver or a putty knife, youll be able to "pop" the clips and tilt the top backwards, form there there ar3 2 5/16screws holding hte front panel on within hte machine.
SOURCE: Maytag electic dryer noise
First, pop up the top of the dryer -- use a large slotted screwdriver under each corner of the top. There will be screws holding the front of the dryer -- take these out and take the front off. The squealing is coming from roller bushings which need lubricating. Apply machine oil to all the axles/bushings -- this most likely will stop the squealing -- and don't forget to unplug it first.
SOURCE: Maytag Quiet Series 200 Electric Dryer
I also had a similar problem with my maytag dryer which is 3 1/2 years old. It was the idler lever assembly with pulley. The part number is 11222607JG and the cost is about $20.00. Hope this helps.
There
can be many reasons why your dryer will not start or turn...
The
most common causes are the belt breaking or jumping off, or the motor
going bad...
Here are a couple of tips that I wrote will help
you to figure out why your dryer will not run...
Dryer Repair
- The Dryer
is not Turning
Dryer
Repair - The dryer
will not start
heatman101
