Remote Start System  Logo
A
Anonymous Posted on Jul 08, 2014
Viper remote starter, car cranks but does not turn over
Derrick Schultz
Level 3:
Top Expert:
  • Viper Master 11,405 Answers
  • Posted on Jan 31, 2019
Derrick Schultz
Viper Master
Level 3:
Top Expert:
Answers
11405
Questions
0
Helped
2331051
Points
23972
Hi there's this website something like reliable-store and it is very amazing for manual for repairing servicing anything
someone on fixya recommended it to me and I thank him even today
They have full manuals and i t's verrrrry cheap and mine
I got free in offers
3rd time I also had an issue with the file so the girl replaced it in 30 mins
there is one more but i don't remember its name it was 2 years back bitman something link this
Try it out brother
5 Related Answers
ltfrc
Mike Schmidt
  • 227 Answers
  • Posted on Jan 17, 2009
SOURCE: viper remote starter
Sounds like the tach connection has been loosened or slipped out of position. Here is a link for installation manuals, Will help in location and inspection of tach wire.
http://www.directeddealers.com/manuals/ig/viper/N5501V_12-06post.pdf
Anonymous
  • 151 Answers
  • Posted on Jan 13, 2010
SOURCE: my viper remote starter cranks engine but car
Did you connect the tach wire of the unit to your car? if not you need to refer to your documentation to turn on or off the tachless operation for the unit to work correctly.
Anonymous
  • 344 Answers
  • Posted on Jan 28, 2010
SOURCE: viper remote car starter 479V
press and hold the ( P ) button until one long beep is heard, you now have 5sec to push the lock button to turn on or off the vibrate, wait another 5sec and it will automaticaly exit programming
Testimonial: "One word,AWSOME!"
Anonymous
  • 306 Answers
  • Posted on Feb 08, 2010
SOURCE: viper 5701 remote issue
sounds like the remots have lost two way communication. try to disconnect the windsheild antenna.try remotes again after pluging antenna back in.
Anonymous
  • 62 Answers
  • Posted on Apr 15, 2010
SOURCE: when using the remote starter the car won't start
have your ignition relay for the remote start checked out.could b a blown fuse.
2answers
2015 Toyota Tacoma with Viper Ds4+ cranks for 20 secs stops cranks then starts.
  1. Cold weather: Cold temperatures can affect the performance of the engine and make it harder to start.
  2. Battery issue: A weak or failing battery can cause the engine to take longer to start.
  3. Starter issue: If the starter is worn or damaged, it may struggle to crank the engine, especially in cold weather.
  4. Ignition system problem: If there's an issue with the ignition system, such as a faulty spark plug or ignition coil, it can cause the engine to crank for a long time before starting.
  5. Viper DS4+ installation issue: The Viper DS4+ remote start system may not have been installed correctly, or it may have a defect that's causing the issue.
Viper starter not turning car over
notify viper or installer for customer assistance
Remot Starter Cranks but car won't start.
I got this free Pdf manual from
reliable-store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of all the times I fixed the chipper in these 4 years
2answers
Remote starter only allows my starter to turn over twice; needs at least 3 with my key. How to adjust to have it starter run longer on remote?
I know you are looking to have the remote starter run a third time but I would say you need to look at your Fuel Pressure Regulator on the Scion. Sounds like it is not holding fuel pressure at the fuel rail and that is why it requires a third Crank
2answers
Which buttons do i push on the viper key fob to remotely start my 2002 ford f150 crew cab. the truck turns over but will not start
you push the ******(star)******* to start it .if it is not starting but starts with a key either wires have come off of remote starter or the remote starter has gone bad.
2answers
Viper Remote starter (Model 4115V1) does not immediately turn on...car will try to turn-over does not and about 45 seconds later, engines turns over. Viper was installed at Best Buy (authorized dealer
It sounds like a problem in the remote start module that was installed. I assume it has not always done this. See what type of warrenty you have on it. Probably none but sometimes suprises happen.
Viper 5101 no longer starts
are your brake lights functioning properly? remote starts sometimes use this as a fail safe, or a bent hood pin switch? Also It may need the tach reprogrammed if used. there may be a seperate fuse for the starter.
here is the link to the installation manual: http://www.directeddealers.com/manuals/ig/viper/n4102v_2008_09_web.pdf
and the page regarding this issue: • The remote start will activate, but the starter never engages.
1. Check for voltage on the purple starter wire two seconds after the remote
start becomes active. If there is voltage present, skip to Step 4. If there is
not voltage present, advance to Step 2.
2. Check the 30A fuses.
3. If the gray/black wait-to-start wire is detecting ground upon activation, the
starter will not crank.
4. Make sure the purple starter wire is connected on the starter side of the
optional starter kill/anti-grind relay.
5. Does the vehicle have an immobilizer? Some immobilizer systems will not
allow the vehicle to crank if active.
6. Check connections. The heavy gauge remote start input wires on the
heavy gauge 10-pin connector should have a solid connection. "T-taps"
or "scotch locks" are not recommended for any high current heavy gauge
wiring.
good luck.
4helpful
Remotes won't program! Installed Viper 5001 on my 2007 Kia Sorento. Triple checked wiring..all is good. Remotes won't program...no power to main unit. Yet, tested main unit and it has power. Any...
There are two constant 12 volt wires at the ignition on this vehicle: blue and green. The red power (with fuses) wires from the Viper should be connected to either of the two. The ignition wire is yellow. The pink wire from the Viper should be connected there. The accessories are orange and white. The pink with white from the Viper should connected to one and the orange from the Viper should be connected to the other. Please note that the Pink with white should be programmed to act as an accessory (off during crank). The starter wire is red and the purple from the Viper should be connected there. Also check for a good ground connection.
For programming:
Press and hold "f" until LED lights solid (approximately 10 seconds), then press and hold remote starter button(circle w/arrow) until LED blinks three times and the amber transmit LED lights up.
Now you have to enter the remote control learn routine: Turn ignition on, within ten seconds press and release control button on antenna then, press and hold control button while pressing the lock button on remote. System will respond (horn/chirp/flashing parking lights) when holding control button and when pressing lock button on remote.
When using the remote starter the car won't start
3answers
My viper remote starter cranks engine but car doesnt start. Seems like strater does not crank long enough. Then it re-tries but never starts the car (Grand AM)
Top Viper Vehicle Parts & Accessories Experts
oneStan
oneStan
ZJ Limited
ZJ Limited
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
