all US motors should have a wiring diagram on the side of the motor unit. The wires going into the pump would hold their same values. I am assuming the previous pump was two speed as well, if not that is your problem.
assuming that they are both two speed reference the common on the pumps motor diagram, and connect the white wire to that terminal.
reference the diagram for correct low speed and connect the black wire to that termial,
repeat for the high speed.
I deal alot with the flo master pumps and they should all be labeled. The most important thing is to get the common correct, switching the other two wires (black and red) incorrectly would simply result in high coming on when low is supposed to and vice versa.
If there really is not a diagram, here is the most typical setup for that motor.
(if you look closely at the terminals on the motor, there are numbers there)
connect the white common to terminal #5
connect the red hot wire to terminal #1
connect the black hot wire to terminal #2
connect the ground
done
Hope this helps.
If this post has helped you, please take the time to vote positively for me on this site.
thanks, and if you need more help, email me @ :
[email protected]
