Question about Dell Vostro 420 Desktop Computer
DELL VOSTRO 420 PANEL CONNECTIONS
HDD LED PWR SW PWR LDD NEED TO KNOW PIN CONECTIONS
    New Friend:
  • 40 Answers
Ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_vostro_desktop/vostro-220_service%20manual_en-us.pdf
Posted on Jul 19, 2014
6ya staff
SOURCE:
Mike McWhinney
  • 537 Answers
SOURCE: Dell gx260 front panel
Try this link for more info:
http://www.austincc.edu/cloud/manuals/Dell/GX260/service/sysbrd.htm
Posted on Jan 30, 2009
Anonymous
  • 1605 Answers
SOURCE: Proper pin numbers to install inserts in a Dell SATA 34 pin GX270 motherboard
why do you need the IDE cable pin out if you are using SATA?
they are diiferent and not interchangeable. if you want to use IDE pin out for SATA, then you need to get a adapter from IDE to SATA.
Posted on May 19, 2009
Anonymous
  • 118 Answers
SOURCE: 34 pin FRONT PANEL insert locations.
http://support.dell.com/support/edocs/systems/opgx270/en/ug/specs.htm
This link should open an html document from Dell, providing you with all the information you seek.
good luck
tony
Posted on May 23, 2009
leecom72
Lee Hodgson
  • 4806 Answers
Hi there.
Get a strong flashlight and a magnifying glass (if you have one). On the motherboard look for the front panel, it should be marked PWR and coloured green, also the plug that connects to it should be marked PWR_SW. On some boards there are no colours but the markings are the same, so take a good close look.
Have a look at these pictures for an idea >>>>>>
Please post back with the results and any more advice if needed.
Good luck and thanks for choosing FixYa!!
Posted on Jun 01, 2009
Anonymous
SOURCE: Dell GX270 SATA front panel 34 pin layout
Link to GX system board layout: http://support.dell.com/support/edocs/systems/opgx270/en/ug/index.htm It's all on a small board and control panel, both of which connect via ribbon cables. Have you removed the power switch, etc from theseboards?
Dan
Posted on Jul 18, 2009
NI996 PANEL CONNECTIONS
N1996 is not a mainboard model number. It is a quality standard code such as CE or UL. You need to provide the manufacturers name and model number if you want answers here.
Jul 08, 2014 | Computers & Internet
CN-O054KME PANEL CONNECTIONS
Assuming that the is a RAMPAGE II Extreme....
Jul 08, 2014 | ASUS P4B533 Motherboard
I have a GA-81865GME-775-RH motherboard, which i put into my box, made all the connections, but have no power once I switch the box on. I suspect it has something to do with the wiring loom running from...
Hello julian_ad681
I will tell you how wire your case front panel, but before that lets test the motherboard to make sure the problem is not the board itself.
Remove all the wire connections to the front panel.
Turn the power on and with a small screw driver or anything that is metal short (touch) the two pins that are the PWR SW. (look at the list of pins I have put at the end)
If the computer turns on then it means the board is ok.
The following information is also availabe in the motherboard manual available from the gogabyte web site download section
On the motherboard next to the battery is the front panel header pins. it looks like
0 0 0 0 0 0 0 0 i also write them as numbers as well to make it easy for you)
0 0 0 0 0
1 2 3 4 0 0 0 0
5 6 7 8
1 and 2 are message LED. you don't need any connection to this.
3 and 4 are the power switch connections no polarity, just connect the wires
5 and 6 are the hard disk LED. 5 is the positive side (usually red)
7 and 8 are the reset switch. no polarity, just connect the wires.
Next to the message LED there is a three pin connection. This is for the power LED.
hope this has helped you.
please leave comment, vote if the helped
Feb 10, 2011 | Intel Motherboard
I Need to see a schematic for a MS-7050 motherboard, in order to determine how to connect the front panel connections, because they are not individually labeled on the board.How or where can I view one?
Pin outs for MS7050 v2.0 HP DX5150 are as follows.
looking from edge of board L to R
First edge pair HDD LED + - First inner pair PWR LED + -
Second edge pair RST SW Second inner pair PWR SW
Nov 26, 2010 | MSI mATX AM2 GeForce 7050 DDR2 Motherboard
I have a PLE01 mother board and i need to plug in the hdd,ldd and ect plugs and i don't know how they go as i do not have the manual and cannot read the small print can u help
Today's motherboard are easy to setup because mostly are now color coded like those connection ports.All you have to do is place the cables according to their color coded ports. Connectors are easy to identified because they are also labeled with name. Like the picture below.
Connections ports on the motherboard are also labeled similar to the connector cables above or have a similar abbreviated names like PSW for Power SW.
I hope this could help you..
Please don't forget to rate. Thanks..
Mar 24, 2010 | Intel Motherboard
Unknown Pin Layout on Motherboard
Here is the pinout. Note key pin 2 missing.
1 2
reset+ O X key
reset- O (gnd) O pwr sw +
pwr led+ O O pwr sw -
pwr led- O (gnd) O hdd led+
-- O O hdd led-
| O O --
| O (gnd) (gnd) O |
n/c -| O O |- n/c
| O O |
-- O (+5v) O --
19 20
Sep 10, 2009 | AOpen EZ65 (ez65white) Barebone
Does anyone know the pin layout for the front panel connector for a EX65-II? (i.e. the UX4SG-1394-II motherboard)
Here is pinout. Pin2 key is missing pin
1 reset+
3 reset- (gnd)
5 pwr led+
7 pwr led- (gnd)
9 n/c
11 n/c
13 n/c (gnd)
15 n/c
17 n/c
19 n/c
2 key (missing pin)
4 pwr sw +
6 pwr sw -
8 hdd led+
10 hdd led-
12 n/c
14 n/c (gnd)
16 n/c
18 n/c
20 n/c (+5v)
n/c = no connection
Aug 03, 2009 | AOpen EZ65 (ez65white) Barebone
I have an 945gzt-m v 1.0 and dont know were the pwr sw wire goes
Yes.
First, let's orient the view of the motherboard, so we are both looking at it the same way.
The processor is at the top middle, and the Front panel header, is to the very bottom right hand corner.
Right next to the motherboard mounting hole.
The Front Panel header goes across the bottom edge of the motherboard, lengthwise.
Looking at the top row of pins on the Front Panel header, No.2 Pin is at the far left. Pins 2, 4, 6, 8 and 10, go across the top.
Looking at the bottom row, No. 1 Pin is at the far left. Pins 1, 3, 5, 7, and 9, go across the bottom.
The power switch wires go to Pins 6 and 8.
The HDD LED wires go to Pins 1 and 3.
The power LED wires go to Pins 2 and 4.
On the power switch wires, the Positive (+) wire goes to Pin 6. Just in case this wire is marked.
(Doesn't really matter which way it goes, because it's a switch!)
On the HDD LED wires, the Positive (+) wires goes to Pin 1.
On the power LED wires, the Positive (+) wire goes to Pin 6.
Apr 15, 2009 | ECS 945GZT-M (V1.0) Motherboard
Front panel connections
You can download the complete user manual in English from the manufacturer's website at this link:)
http://support.asus.com/download/download_item_4.aspx?product=1&model=P4B533&SLanguage=en-us&os=17
The front panel connector pinout is on page 2-33, or page 59 in the PDF file. You should have mor ethan enough information to make all the connections you need.
Jan 02, 2009 | ASUS P4B533 Motherboard
PWR > PWR (aka PWR SW), HDD LED > HDD LED, RST > RST (aka RST SW and Reset)
May 31, 2008 | Iwill XP333-R Motherboard
Open Questions:
See all Dell Vostro 420 Desktop Computer Questions
Dell Vostro 420 Desktop Computer   Logo
230 people viewed this question
Ekse
Clive
Clive
Alun Cox
