My USB2 SDR-TV wont work properly on any USB port on my L50-A under Win 8.1, the driver and software loads but as soon as the stick tunes to a station I get a blue screen. Windows trouble shooter says to run it on a USB2 port. The documentation for the computer says the left hand port is a USB2, but it doesn't work there. Can I change the USB port type? The stick works fine on an old XP machine.
SOURCE: Screen resolution resets to 800x600 after every reboot when d/port is connected.
You may have to set the monitors resolution to match the pc as they may be different.
SOURCE: Problem with USB ports on PA286A port replicator
is the usb port not detecting any other device or just to your docking station or if you plug any usb device and you get the message like not supported or may have a problem can you do that test and give me some more info
SOURCE: keyboard problems
yes in some issues i have encountered the ribbon that plugs the keyboard in may be corrupted or you may have a bad keyboard
SOURCE: No HD audio on Toshiba Satellite under Win XP Pro; Vista works OK
You almost have it correct. There is one more patch you must install before SP32646.
Read about kb888111.exe file from
http://support.microsoft.com/kb/888111/en-us
But kb888111.exe is not available at that link. It is here:
http://geekswithblogs.net/lorint/archive/2006/06/11/81540.aspx
Then re-install Microsoft Universal Audio Architecture (UAA) Bus Driver for High Definition Audio (SP32646), and finally install the Conexant High Definition Audio Driver
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1209146&rpn=PSPA6U&modelFilter=P105-S921&selCategory=3&selFamily=1073768663&selModel=1209146%7CPSPA6U#
SOURCE: CL51-15 USB Port Problem
I was hoping you can help me out guys, i have this laptop acer travelmate 290 and everything seem to be working properly. All the drivers and devices are installed and working fine(Audio, Display, Network, Wireless, PCMCIA......) except my 2 USB port. I tried almost all devices on it but nothing works and cannot be detected at all ( mouse, keyboard, cam, printer etc...) Device manager say's my usb port is working properly and has no conflict at all.
OS : Windows XP Pro /SP3
USB Controllers
USB: Intel(R) 82801DB/DBM USB 2.0 Enhanced Host Controller - 24cd
- ...... 24c2
- ...... 24c4
- ...... 24c7
- USB Root Hub.....
Everytime i plug something on the USB port i dont see any respond at all, like new usb device was found or somethin message pop up on the lower left on my screen. Nothing at all.
Hope you can help me out guys
