Hi Anonymous, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? What is the model of this cordless or corded phone?Hi Anonymous, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? What is the model of this cordless or corded phone?
AnonymousJun 22, 2017
I think you're talking about wallpapers just tap and hold for 2 seconds on home screen it will provide with more options and there you can see wallpaper and if this is not the case then you can try the to contact the Motorola SupportI think you're talking about wallpapers just tap and hold for 2 seconds on home screen it will provide with more options and there you can see wallpaper and if this is not the case then you can try the to contact the Motorola Support
You can't post conmments that contain an email address.
hi there , you have to enter settings , tone settings, then you select loud , then select loud details , you can change the message tone , the alert tones , the ring tones from there.hope this helps.. Simon
i had same problem trying to receive faxes until i changed phone connections.
according to a motorola manual (link below) this has something to do with being connected to a "proper analog phone line".
i had the phone line running from wall to a newer gateway (maybe 8 months) dec 07 to a maybe 2 year old compaq. kept getting that loop current error on the compaq when trying to receive a fax until i elimated the gateway connection and plugged the wall right into the compaq.
here's a link that might help: http://downloadmirror.intel.com/12655/ENG/Motorola.htm
see section 6, troubleshooting. hope this helps...
You may change your message ringtone directly from file manager. Go to ringtone file you want to select, then select sent to option there is a tab "as message tone" select it. And it will be so.
