Garden Logo
A
Anonymous Posted on Jul 08, 2014
Ryobi BP42 leaf blower will start but will not rev - how can I fix this?
The leaf blower is hard to start, but eventually will idle very low. However, when I push the trigger to add gas and allow the blower to run harder, it just turns off like it is getting flooded. Any ideas?
  • 2 more comments
  • Jose
    Jose Apr 01, 2016
    Spark arrestor
  • William Frankford
    William Frankford Jun 05, 2018
    On this model, there is what I would call a factory defect. There is a tiny hole in the heat dam gasket on the engine side of the carburetor that is situated too close to the large air intake hole. The gasket will eventually fret away between the small hole and the large hole due to the high velocity air flow. The end result is that the small hole opens up to the large hole causing the carb to supply too little fuel and bog when you rev it up. Replace the heat dam gasket and the blower will work properly.
  • Anonymous Oct 31, 2018
    Yes, I replaced the gasket and it works great now! I wish I would have found this out prior to spending hours on this darn thing, but it's fixed now!!
  • Anonymous Jan 16, 2019
    Is it the gasket that is right behind the carburetor itself (562927001) or the on on the other side of the heat shield, against the engine (562927003)??
Jeff Hagemann
Level 2:
  • Expert 430 Answers
  • Posted on Jul 28, 2014
Jeff Hagemann
Expert
Level 2:
Answers
430
Questions
Helped
251868
Points
918
Its actually the opposite of flooding. Its lean. Adjust carb or rebuild carb.
  • Jose
    Jose Apr 01, 2016
    Spark aresstor
Jose
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 01, 2016
Jose
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
12247
Points
9
Sometimes the spark arrestor gets plugged up with soot.
Take it out and clean it or buy another. It unscrews like a spark plug. I forgot where it located but look around you'll
find it somewhere.
4 Related Answers
Anonymous
  • 8 Answers
  • Posted on Nov 11, 2008
SOURCE: ryobi leaf blower #8544,25.4 cc
I have a McCulloch, that the hose rotted off the fuel strainer in the tank, I replace the hoses, it ran for awhile then stopped, removed the carb. an have cleaned, { 7 Times} it runs for awhile then stops, Usually I dump lighter fluid in the carb. if it starts Ign is OK if not its a fuel problem. You could check on the filter, I still have a problem with mine, its a pain when your on the roof an it stops. so check the fuel filter is the only thing I could suggest to you GOOD LUCK
Anonymous
  • 15 Answers
  • Posted on Apr 19, 2010
SOURCE: yard broom leaf blower will not stay running I
It seems that the carb is not getting fuel. It could be a cracked fuel line. The fuel priming bulb could also be cracked/dry rotted. Possibly the fuel pump in the carb is bad. The carb is rather intricate and not something anyone without training should try to repair. The overhaul kit will cost $15 to $20. I suggest you take the blower to a repair shop.
Testimonial: "Thanks will do"
Anonymous
  • 63 Answers
  • Posted on Mar 20, 2009
SOURCE: My leaf blower will not start, It keeps flooding
To start: turn the choke off, hold the throttle wide open and crank. You have a carb problem but this should get you going. John
Please rate if this helps-
Mike McDowell
  • 148 Answers
  • Posted on Aug 24, 2009
SOURCE: Echo leaf blower is bogging down at full throttle,
Have you tried cleaning the carb?
Testimonial: "Thanks for the suggestion, that sounds like what it may be. "
How to change a spark plug on a ryobi BP42 back pack leaf blower
06b6b378-bffc-4c24-8f00-10bffdb3a0ac-ekquliymz1b0kl13j1i4m1y0-4-0.png No. 20 is spark plug, hopefully this will help.
Ryobi bp42 leaf blower making a rattle noise
first thing to check is a branch/trig stuck in the tube and hitting on the blower impeller fins
1helpful
Ryobi BP42
Could be mixture is too rich. also check if carburetor is flooding the engine.
Ryobi problems
sounds like you have either a dirty carb or a small air leak
Aug 11, 2014 • Garden
Ryobi BP42 leaf blower will start but will not rev up when I push the trigger - how can I fix this?
Its a lean condition, not getting enough fuel. Check fuel filter and fuel lines. be sure you have fresh fuel. and the carb needs to be adjusted or rebuilt.
Ryobi leaf blower idles, give it gas it stalls
strip and clean the carb then try it again it has no doubt been sitting a long while and has corrosion and sediment in the carb blocking it up ,if you pull the choke as you rev it it will rev with the choke on ,dirty carb
2answers
Low RPM's Ryobi 25.4 cc backpack blower
Remove the muffler and you should find that it will run at full speed. The muffler is clogged with carbon. You will have to replace the muffler since it is sealed. If you want the muffler cleaned you can contact southern supply company at 205-833-2525 or email them at
[email protected] and I feel sure Jason or
someone there can help you.
Ryobi RLT30HT hard to start, won't tick over
Hi
On the rotochoke scale, between the run and half choke position there is a hole and in it there is a screw. This adjusts the idle. Turn clockwise to speed up, anticlockwise to slow down
The trigger on my ryobi backpack is not functioning properly.
You need to buy a new cable, clarified by Ryobi Tech Support.
Top Ryobi Garden Experts
Jay Finke
Jay Finke
john h
Steve Sweetleaf
Steve Sweetleaf
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
