Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls
·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open
·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset
·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
SOURCE: Frigidaire model ftr18b freezer works, fridge is only cool
Info relating specifically to the Frigidaire FRT18B5ABB:
1.Refrigerator unplugged remove the bottom back panel. (Access cover with label. The rectangular shaped panel on the back, at the bottom) Place the screws in a container.
Also remove the Kickplate Grille in the front, and the defrost pan.
2.Use the wand tip on your vacuum cleaner, and vacuum this area out. Pay special attention to the condenser coils, and the fan. Use care as you don't want to bend the fan blades. After you have vacuumed up as much as possible, see if your vacuum has where you can attach the hose to blow air through it. An air compressor, hose, and air nozzle would be REAL handy right now! Blow the condenser coils, and all areas clean of any gunk. (Hair, spider webs, etc.) If this is not feasible for you, you'll need some sort of long, thin, dust 'bunny', and have to dislodge this 'gunk' physically. Then vacuum.
3.BE SURE to replace the bottom back panel, (Access Cover)! It is a VERY necessary item! If your fridge doesn't have one at present, make a temporary one of cardboard, and tape it on. This access cover is needed.
If your refrigerator side is only cool, and your freezer is cold, you may have a problem with the Cold Control, (Temperature Control), or the Defrost Timer. (Timer-Defrost)
http://disruptit.com/manualgateway.cfm?pdfwanting=34242&username=anon&AV=123345&I=99.169.118.45
SOURCE: We have a Frigidaire side
if the freezer is warming up slowly,check the rear wall of the freezer inside for frost which would indicate a defrost problem,otherwise,if the freezer has been holding its own temp for some time,then its probably the damper vent door located between the refrige and freezer section wall in the upper left hand side of the refrige section behind a plastic grille,you should hear the evaporator fan running and feel cold air entering from the freezer in this area,you can remove the grille cover and if its froze in place you can deice it with a hand held hair dryer,otherwise they do break and lodge in position or the motor that controls it can be defective or without power to operate
Hello friend, thank you for your post!
From my understanding your Frigidaire refrigerator is beeping and you have to reset the temperature. You're stating that it was used excessively on a warm day, it could be that the temperature is attempting to stabilize. If the door was opened and closed a lot then your appliance did not have an opportunity to cool down and that is why the temperature alarm needs to be reset. I would allow your appliance to properly get back to a cool setting, it could take 24 hours to properly stabilize.
If your refrigerator continues to beep reach back out I would be happy to provide you more assistance. -Matt
Hi katelynn_did - When the refrigerator is beeping or buzzing, it may be a warning sign of a possible malfunction or an unsafe, interior temperature. Typically, that is correct, to silence the buzzer, you can depress the ALARM OFF button. However, since you have already tried unplugging the unit and issue persists, it could possibly be experiencing a communication problem with the temperature control/board, faulty internal sealed system or wiring failure. I would recommend connecting with a professional appliance tech for a clear-cut diagnosis.
Good Morning Friend, I understand you Frigidaire refrigerator is beeping and is not staying cool. I will be more than happy to assist you. So I am able to better assist, I kindly ask that you provide the model number of your appliance. Typically, you will find this on the inside of your refrigerator, either on the right or left hand wall. Looking forward to hearing from you. -WP-
4a20703308
