My HVAC system started leaking today - behind the filter (which was filthy) was a sheet of ice. I have a Versatec manufactured by WFI unit. Does this sound like a filter/had the unit on too high problem that once I clean up all the water and dry the wall that I can use the unit again or does it sound more internal to the unit? Thank you!!!!
There's only one way to find out. Yes, a dirty filter can cause a coil to freeze. Once frozen water drips off and misses the drain pan.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Clean the coil if possible if not call a tech, pour water down the drain or drizzle it on the face of the coil and see if it drains or overfills the drain pan, you should schedule a professional cleaning in any case.
SOURCE: Friedrich air conditioning - inside unit ice build up
Hi, Reduced air flow, low on freon or being continuously run during cooler weather such as at night. Some people turn their thermostat on 60 thinking that it will help get it cooler faster. They freeze up at night and don't get a chance to thaw during the day. It needs set no lower than 75 or so. The evaporator may be dirty. Don't know a lot about your particular unit but if the outside unit has the compressor and refrigerant lines running to it, The large refrigerant line should sweat all the way to the compressor if its fully charged. Please rate me if I have helped. Good luck kstfas
SOURCE: Wall ac unit keeps freezing up inside.
No! You will not likely find any service on a product which has very little value. Frosting will sometimes happen if the outside temperature is to low. The outside ambient temperature is directly related to the pressures inside the refrigerating system. The lower the outside temperature is the lower the pressures will be in the cooling end of the air conditioner. In mechanical refrigeration pressures and temperatures are directly related.
SOURCE: Reverse cycle heat pump leaking inside
The condensation line is clogged.It can be cleaned from outside with a wet/dry vacuum (shop vac)
Please rate this Fixya
Do not run it on maximum cool and fan on low. Freezes up all the time this way.
SOURCE: condensation leaking out of unit
if it is the indoor unit leaking, make sure that all your drain lines are clear.... if you're talking about the outdoor unit leaking water in the heat cycle...that is normal.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cody_17f08cf8e340c06c
