Broderbund PrintMaster Platinum 15 Full Version for PC (385502) Logo
A
Anonymous Posted on Jul 07, 2014
My program froze while I was creating a design and I can't unfreeze it. If I shut down the computer when I reboot it is still there with the little color curser spinning. I have work to do. Help!
A
Anonymous
Are you sure you're actually rebooting your computer and not simply turning the monitor off and back on?
1helpful
Unfreeze sony xperia
Please try this
>Press and hold the 'Power' button and the 'Volume Up' button
>Wait for around 5-10 seconds
>Your device should then vibrate and reboot (hopefully) rectifying the teething troubles you were having!
Aug 10, 2013 • Cell Phones
7helpful
How do I unfreeze the screen?
Press and hold the power button for fifteen seconds or so, ignoring the "Shut down?" prompt until it shuts off. Release the power button, then press and hold for a second or two until the Kindle starts rebooting.
How do I unfreeze screen on iview702 will not even shut down
you can try removing the battery manually so it will shut down.
9helpful
4answers
My tablet froze... how can I unfreeze it?
if its anything like an samsung tablet hold the power button down for atlest a min. I had to hold mine down for 30 seconds to get it to reboot
1helpful
My psp froze on the internet and it whont unfreeze.
Reboot it by sliding the power button to off and holding it there. If it still doesnt shut down pull the battery out then hold the power button for 10 seconds. Put battery back in and reboot. Also check to make sure that there are not any updates available for your PSP
I plugged in camera, new just bought took a few pictures and did what the paper instructions inside box said to do.Plugged it into laptop, and pressed share it downloaded into computer but still is ...
There's not much choice here. If your computer is frozen and you can't use the "safely remove hardware" function to disconnect the camera, then you need to turn off the camera, then remove the cord. You will need to do a "hard shutdown" of your computer by pressing the on/off button until the computer shuts down. I wouldn't try the same download procedure again. I would get a separate card reader and use it to download to a folder I create on my desktop. From there, you can import the pics to any program you wish. typrice_102.jpg
4helpful
Trio model t3000 sozen up
I just purchased my T3000 yesterday and it froze after taking a picture. To unfreeze, there is a pinhole at the bottom of the device (on the opposite end of the headphone jacks). Stick a paper clip or pin into the little hole to force a reboot. Hope this helps.
My LG Tritan randomly restarts itself when I am texting or using the browser. It doesn't do this all the time, just randomly. It started after it froze up and I had to take the battery out of the phone for...
mine does the same thing lg says that it is a automatic reboot function for when it gets confussed or freezes and it is also programmed to shut off when dropped
2answers
Laptop runs hot and freezes - heat damage or Power supply issue?
Check the heat sink..if its not properly insatlled the somputer reaches the warning temp and shuts down the processor to prevent damage..you may have to replace it if its damaged..heatsinks dont cost much..
2answers
It was working before computer had to reboot
download and install the firmware/driver for the device at www.sandisk.com
Top Broderbund Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
