Assuming you are referring to the Coleman Campers Grill Stove which is a side by side grill and stove unit than it is a pretty simple set up. All portable Coleman stoves set up basically the same. There should be a arm known as a regulator that came with the stove. The narrow end of this attaches to the right side of the stove and screws in. Then the propane bottle screws into the other larger end. make sure all connections are screwed together tightly. For more clarification check out these instructions:
http://www.ehow.com/how_2106008_use-coleman-stove.html
https://www.youtube.com/watch?v=dbYil-YQ8-Y
Good Luck!
No. You should only use propane, as directed, in a propane camping stove.
