SOURCE: deisel pump problem
ok its a diesel and disels come with a glow rod attachment you have to turn key on let sit for minute while rods heat back up and then start it
SOURCE: on our 1996 ford taurus the return line connection broke off.
IF this Hose Nipple is A Casted Aluminum or iron and is "part of" the Thermostat Housing Simply ( Replace T-Stat Housing itself),,,, If it is Part of the INTAKE MANIFOLD Ouch!! Replace Intake manifold. I Hope this Sheds Light on your Problem so as to Lead to A Good Repair for your Vehicle, If this does help
'in any way" PLEASE don't forget to RATE me as to Your Discretion
SOURCE: Engine Oil Capacity 1996 Chrysler Cirrus
according to my info, a 1996 Cirrus with a I4 2.4L (the eighth digit of your VIN number should be an X) engine carries 5 qts. of oil
SOURCE: oil pump replacement
The pump is located in the pan you have to remove the transmission bolts out and raise the engine up with an engine stand and remove oil pan bolts and remove pump, it's quite a job.
SOURCE: where is the oil pump?
Probably not. Make sure you have a clean oil filter and check the oil level. Also, make sure the oil filler cap is secured.
