SOURCE: Magic Chef MCBR415S cabinet get's very HOT!
* Is your compressor motor running all the time ?
* have you checked and cleaned your condenser coils at the back ?
* Is there sufficient airflow around your refrigerator (especially at the back) ?
* Is your refrigerator and freezer cooling properly ?
Sounds like your unit is working overtime - it will usually get hot like that when compressor motor has been running a long time and heat does not dissipate properly at the back - it also gets hot after a defrost cycle - it should NOT be hot at all times. CHeck to make sure your temps are correct to rule out a stuck defrost cycle timer - your refrigerator should not be hotter than 40F and your freezer's temp between 0F-10F, the optimal temp is 0F.
