Samsung 24 in. DB5710DT Stainless Steel Built-in Dishwasher Logo
A
Anonymous Posted on Jul 07, 2014
How to fix the upper fan on a Samsung RF217ACBP?
Radu Laurentiu
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 09, 2014
Radu Laurentiu
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
157
Points
Evaporator fan.. that would be in the bottom drawer behind the wall... Bottom drawer has to come out. everything out of the freezer, some models (LG) bottom freezers have to evaporator fans. Similar design, both companies make similar fridge
  • Radu Laurentiu
    Radu Laurentiu Jul 09, 2014
    two evaporator fans, not one... upper fan?? what are you referring to ??
Samsung French door compressor and evaporator fan are running but no air blowing out upper and lower and upper fan is not running. Do you have any clue? I do appreciate.
If ice buildup on back of the fridge compartment there will not be any air flow and with the doors open fans won’t run
My Samsung refrigerator model#RFG29PHDWP is pouring water out of the ice maker. What can cause this?
low freon refrigerant...the lower part of the freezer is cold and the upper is not ...sometimes there is an internal fan that sticks or shorts and simply cant get the cold air to the top ..it is one or the other...hopefully the fan ..it is a quick fix for most technicians..GOD bless
Samsung RF217ACBP keeps freezing the ports inside the refridgerator. Then the fan motor starts
Their is a fan circulating air through out the unit. If this fan is not working you will experience what you have discribed.
Where is the drip tray
USUALLY IN BACK ,LOWER PART NEAR THE COMPRESSOR OR AT THE FRONT SECTION BOTTOM
6helpful
2answers
Have a Samsung RF217 Refrigerator that is collecting water in the right vegetable bin? Fridge does not have ice maker.
Just had mine repaired. The evaporator drain is plugged with ice. The solution is to replace the heat sensor and add a piece of metal extending from the small heat coil under the evaporator that supplements the piece already there. The guy that repaired mine used a piece of coat hanger wire for the extension. Except for the heat sensor, it's a repair anyone can do. Just take off the plastic cover on the inside back of the fridge, melt the ice obstruction in the drain and hang a piece of wire from the heat coil into the drain. He also used some metallic duct tape to raise the height of the drain tray on the ends so that it wouldn't overflow in the future.
1helpful
Error Code E3 displayed on Samsung wine cooler model RW13EBSS, even after power off and reset.
"E3" on display for upper zone - error of DC
electric fan for upper zone.
I had an E3 on the upper zone. This fix was simple. Unscrew the 2 screws for the middle tray. Pull tray out as far as you can. Check the wires in the back, those are the wires for the fans in the back. The connectors over time corrode, and break off... All I did was connected the 2 wires that had broken off of their connector directly to each other. E3 went away and the cooler is working as it should now.in
Model RF217ACBP - freezer defrosting but says it is -2
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Top Samsung Dishwashers Experts
vince
Daniel Blask
Daniel Blask
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
