Hello preslncon - The black button that you are referring to is more than likely the Hi-Limit Thermostat. The Hi-Limit Thermostat will open and stop power from reaching the heating element. The Hi-Limit is not resettable, and if it is open, it would need replacing. As far as the burnt wire on the Thermostat, more than likely a loose connection to the Thermostat could have possibly caused the wire to overheat. This is not a typical do it yourself job. Personally, I would recommend reaching out to a qualified appliance repair person to proceed further. I hope this information helps to some degree.
