Hayward SAND FILTER, PRO SERIES Logo
A
Anonymous Posted on Jul 07, 2014
Need picture of hayward vari-flo value wedge - Hayward SAND FILTER, PRO SERIES
5 Related Answers
Anonymous
  • 61 Answers
  • Posted on Apr 04, 2009
SOURCE: using a hayward vari-flo valve model SP 710x32
Do not drain a vinyl liner pool mor than half way....ever... If you have a fiberglass, or gunite pool it is important to pull the hydrostatic plug under the main drain cover. If you live down a hill, or where there is a high water table, the water pressure underground can lift the empty pool out of the ground (more common in fiberglass pools). If you have a sand or DE filter switch the valve to waste. make sure that you have the skimmer turned off, and the pump is only sucking from the pool main drain (spa drain closed also), and turn the pump on. Make sure the waste hose is far enough away so you dont add any hydrostatic pressure.
john224
John Prohaska
  • 1378 Answers
  • Posted on Jun 26, 2009
SOURCE: Problem with vari-flo multipoer 1.5 and Hayward DE fiilter
You need a rebuild kit for the valve and possible a sand change. Sand should be changed ever 3 - 5 years or so depending on overall pool conditions.
The gasket inside the valve is out of place and therefore allowing water to leak out the waste port. Use a gokit to replace all the gasket/orings and you should stop the leak.
If the flow is still bad, inspect the sand and change it if necessary.
john224
John Prohaska
  • 1378 Answers
  • Posted on Jul 17, 2009
SOURCE: Hayward vari flo valve
It will not be glued, it is just stuck in there good. You will need to scrape, pull, twist or otherwise convince it to come out as best you can and then clean the area well before installing the new one.
Coastsider
Charles East
  • 331 Answers
  • Posted on Apr 14, 2010
SOURCE: How can I find the installation instructions for
http://www.haywardnet.com/inground/products/displayProd.cfm?ProductID=66
thepool
thepool
  • 78 Answers
  • Posted on Apr 22, 2010
SOURCE: Hayward vari flo filtering system
Check to make sure the plumbing is in the correct inlet/outlet on the valve head. Sounds like it's plumbed backwards. Inlet is from the pump, out to pool...
Replace spider seal in Hayward Vari-flo, do I just put new seal in or do I glue it in? Tks
no you do not glue it in. use a proper lube on both sides of the new spider gasket
Need help replacing a Hayward Sp714T Vari-Flo Xl
Copy following link for Hayward manuals:
http://www.hayward-pool.com/prd/In-Ground-Pool-Manuals_10201_10551_14502_-1___I.htm
You can also contact Hayward
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Hayward Vari-flo Xl
You have a bad o-ring at the flange... or the clamp is loose?
4helpful
1helpful
Glass part that screws on is broke
It is the sight glass. If you would like a quote, contact us at www.arrowpools.net for one.
Our sp0710 vari flo multiport value in the filter position is letting the water run out of the filter like it is in the backwash position
SHUT OFF PUMP TAKE HANDEL AND MOVE TO DIFFERENT POSITIONS TO SEE IF THERE IS CHANGE THERE IS A WHEEL UMDER HANDLE THAT MAY BE OUT OF POSITION TRY A COUPLE OF ROTATIONS START PUMP AND THERE SHOULD BE A CHANGE NEVER TRY TO MOVE HANDLE WITH PUMP ON
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
john h
ZJ Limited
ZJ Limited
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
