Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS.
The 4 top line/feature keys are now used for
programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program ringing on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear only
press the Chng key till it says appear & ring
press next key (lower right arrow)The display should say line 002: appear only
repeat procedure for remailing active lines
If your system uses the older programming template,
then Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
the display says A. Configuration
programmingPress the show key (top right arrow)
the display will say1. trunk/line
data Press the next key (bottom right arrow) .
the display will say 2.line access
the display will say line assignment
Press the next key 2 times(bottom right arrow) .
The display should say ringing.
Press the show key (top right arrow).
the lines should be listed as appear only change to appear and ring
press Rls when finished
