Question about HP Officejet Pro L7680 All-In-One Printer
How do I clean the print head on an HP Officejet Pro L7680 All-in-one?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 5 Answers
Both of these website URL links should help you. The first one explains how to do it. The second one is a video that actually shows you how you go to the menu on your screen to tools then "clean printheads"
http://www.ehow.com/how_8409367_repair-head-problems-hp-l7680.html
https://www.youtube.com/watch?v=8Zl0LUxBSvg
I can't post this answer... the verification box won't accept any typing characters in order to submit this answer...
Posted on Jul 08, 2014
    New Friend:
I am assuming that you have installed the HP Solution Center software onto your PC. If not go online to hp.com, do a search for it, download and install it.
1. Open HP Solution Center
2. Click on Printer Toolbox
3. Click on Services (top)
4. Click on Clean the Printheads
I’m happy to help further over the phone at https://www.6ya.com/expert/james_16b2a71caf566999
SOURCE:
myob247
  • 1342 Answers
SOURCE: HP L7680 Print Heads need real cleaning!
If the ink has dried up in the nozzles try putting a wet cloth in the microwave to get it hot enough to produce a little steam and set the cartridge, nozzles down on the damp cloth until ink starts to ooze from the cartridge. May require a couple of tries. Try using the cleaning program again.
Be careful not to touch the copper contacts on the cartridges.
Posted on Apr 27, 2008
websnail
  • 419 Answers
SOURCE: when printing on my HP
The HP88 printhead can dry out and cause clogging in the black part of the K/Y (black/yellow) printhead.
This has been a major problem for a few client schools of mine and for me in my attic space where air conditioning and/or hot dry air causes clogging.
You may want to consider purchasing a new printhead and an alternative black ink supplier (non HP) that uses Dyebase ink instead of pigment as this doesn't clog in the same conditions.
However, please note that if you do this it means you may lose your warranty (certainly on the printhead) and the printout won't be as clear for text as the black ink can "bleed" slightly into other colours. It has however solve the problem of clogging in one school that went through 5 printheads in two terms/semesters until we switched.
Posted on Jan 23, 2009
jimfernbank
  • 31 Answers
SOURCE: How to set date/time on HP Officejet Pro L7680
Instructions are on this web page:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01566785&lc=en&dlc=en&cc=us&product=2512009&rule=29401&lang=en
Posted on Mar 25, 2009
SOURCE: HP officeJet Pro L7680 will print in color but without any black.
I have the same problem with my Officejet Pro L7780, so you are not alone. Have you found any solutions?
Posted on Aug 17, 2009
  • 71 Answers
SOURCE: HP Officejet Pro L7680 prints half page only
to get to the root cause of the problem . you can try printing from the notepad and check it prints fine from the notepad . if it prints fyn then there can be some issues with the software compatibility.. which version you have for microsoft office.
Posted on Oct 20, 2009
How do I clean HP officejet Pro L7680 All pictures have severe vertical lines??
Have you tried the "clean print head" option in the HP Officejet Pro software on your computer? This will often fix verticle lines. But, it will use a lot of ink.
Nov 04, 2014 | HP Officejet Pro L7680 All-In-One Printer
How do I remove old printheads
Hi the below website explains how to fix print head errors and how to remove/replace the print heads in HP Officejet Pro L7680 All-In-One Printer
http://tinyurl.com/raj12345
Best Of Luck.......
Dec 09, 2010 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L 7680. Print. Tops of letters are cut off just in one area of print-just happens to be the numeral check amount. Tools: Alignment failed.
Do a full cleaning of the print heads from within the printer tools control panel in windows. You either have a very bad clog in the ink nozzle or a print head that has failed. If the cleaning does not solve the issue then replace the print head.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Dec 14, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP L7680 won't print black, cartridge is new, says it is full, Self diagnostic page says printhead is good
Try printing a Diagnostic page or clean cartridge. Looks like the printheads might be clogged due to low usage or general wear and tear, they may not be working as desired.
Oct 26, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 When printing a power point presentation, lines are printing over the jpeg pictures on the slide
There is some problem with your print heads. Run a print diagnostic report and see if it helps. You also may want to trigger clean cartridges if triggering print diagnostic page does not help.
This issue may happen if the printer is not used for few days. Recommend to keep the printer powered on always, or then trigger print diagnostic page as it tries to unclog the blocked print heads to give you a clean print.
Hope this helps.
Oct 24, 2009 | HP Officejet Pro L7680 All-In-One Printer
Jun 03, 2009 | HP Officejet Pro L7680 All-In-One Printer
Apr 27, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 All-In-One Printer Logo
265 people viewed this question
Clive
Clive
Thomas F. Schneider
