Xerox CopyCentre C128 Black and White Copier Logo
A
Anonymous Posted on Jul 07, 2014
Xeroc workcentre error 09-560 - Xerox CopyCentre C128 Black and White Copier
Machine Xerox printer Workcentre 3210. Invalid Toner message continues, even though the toner has been removed and reinstalled.
You must use Genuine Xerox supplies from Xerox, especially if you are on a lease and supplies deal. You slip a refilled or 'compatible' replacement toner from 'The Toner Guys', the machine locks you out until reset by a Xerox tech.
https://forum.support.xerox.com/t5/Hardware/Invalid-Toner-Cartridge-error-Workcentre-3615/td-p/199538
and although it is a different model, it is the same series
Turns out the WorkCentre 3615 has two types of toners - None Metered 106TO2722 and Metered 106RO2724. Both toner boxes say WorkCentre 3615. You must order the correct one or you will get this error and the machine won't work at all. Who knew? Xerox admitted they sent us the wrong one, so they are offering to fix with a code over the phone.
https://www.google.com/search?q=xerox+workcentre+3215+invalid+toner+cartridge
Error code 39,003,40;61256 on a xerox workcentre
Here is the easy solution to fix the issue :
Click on the link and follow instructions to fix the issue.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
7helpful
2answers
Error 016-311 xerox workcentre M128
This error code means the Scanner is not installed. The reason for this code could be a bad or diconnected interface cable, or corrupt system software. Check the cables for connectivity. If the problem persists, it will probably require a call to Xerox service. 800-821-2797
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
1helpful
Xerox Workcentre M201 says open heat error
Fuser Error, Open Heat
Error, Heating Error and
Overheat
There is a problem in the
fuser unit.
Unplug the power cord and plug it back in. If the
problem still persists, please call for service.
2answers
Error message
gearbox error refering to the printing tilting. probably have to have a service call
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
