Audio wiring foxcom n15235
n15235, useless this.that is electrical certs number
top of mobo has stickers only THEY matter.
but sorry if is Foxconn 6627MA-RS2H (2007 made)
SiS 662
Pentium D / Pentium 4 HT / Celeron D
DDR2 667
bad news SIS is dead now and so is foxconn diy mobo support by them 2019 they ended DIY kit business.
you need the Audio port jacks from the front panel
not the rear that is a standard, green is output. end story there, pink mic. etc.
you lost the CD out of the new box I see, so lost the PDF manual there too, ouch.
then answer for pin header, marked
Audio Interface: F_AUDIO
is here
https://manualmachine.com/foxconn/6627mars2h/1611735-user-manual/
For 6-Channel (optional)
The audio interface provides two kinds of audio output choices: the Front Audio, the Rear Audio. Their priority is sequenced from high to low (Front Audio to Rear Audio). If headphones are plugged into the front panel of the chassis (using the Front Audio), then the Line-out (Rear Audio) on the rear panel will go offline. If you do not want to use the Front Audio, pin 5 and 6, pin9 and 10 must be shorted, and then the signal will be sent to the rear audio port.
see graphic of jack same page.
