SkyScan 86709 Atomic Wall Clock Logo
A
Anonymous Posted on Jul 06, 2014
The projector on my atomic clock is displaying incomplete data
Dot Hall
Level 1:
New Friend:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Jul 07, 2014
Dot Hall
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
8
Questions
Helped
5281
Points
19
Go to the subject line in your browser and type in Atomic clock instructions. Most all of the makers of this type of clock has a HELP section and the instructions included! I hope this helps!
D.M. Hall
I have a Sharp Atomic clock , model SPC373 and the time is incorrect. Everything else is ok, how do I correct the time?
To correct the time on your Sharp Atomic clock, you will need to reset the time zone. To do this, press and hold the "Time Zone" button for 3 seconds until the time zone flashes. Then, press the "Hour" and "Minute" buttons to adjust the time zone to the correct time zone. Once the time zone is set, press the "Time Zone" button again to save the settings. The clock should now be displaying the correct time.
Aug 13, 2022 • Home
Why does my Centrios Atomic Nature Clock Radio keep changing time at night?
https://mb.nawcc.org/threads/setting-a-centrios-atomic-clock.32197/
If the atomic radio controlled clock is off by one or more hours, it probably has to do with the time zone setting. ... Other atomic wall clocks may allow the selection of any time zone, even time zones that are outside the WWVB coverage area. When purchasing a clock, make sure that it can display the correct time zone. https://www.weathershack.com/static/ed-atomic-clock-synch.html
Lacrossetechnology
Hi Susuan,
One of these methods below should get your device working properly. Good luck!
LaCorosse Tech Support email address.
The product information page
From the manual:
915MHz RECEPTION CHECK FOR OUTDOOR TEMPERATURE SENSOR
The atomic clock will receive the temperature data within 3 minutes. If the temperature data is not being received 3 minutes after setting up (the display shows "- - -"), then please check the following points:
1. The distance of the atomic clock or outdoor temperature sensor should be at least 6 feet (2meters) away from any interfering sources such as computer monitors or TV sets.
2. Avoid placing the receiver onto or in the immediate proximity of metal window frames.
3. Using other electrical products such as headphones or speakers operating on the same signal frequency (915MHz) may prevent correct signal transmission and reception.
4. Neighbors using electrical devices operating on the 915MHz signal frequency can also cause interference.
Note:
When the 915 MHz signal is received correctly, do not re-open the battery cover of either the outdoor temperature sensor or atomic clock, as the batteries may spring free from the contacts and force a false reset. Should this happen accidentally then reset all units (see Setting up above) otherwise transmission problems may occur.
The maximum transmission range is 330 feet (100 meters) from the outdoor temperature sensor to the atomic clock (in open space). However, this depends on the surrounding environment and interference levels. If no reception is possible despite the observation of these factors, all system units have to be reset (see Setting up).
How do i set a radio controlled clock seth thomas hd 1688
  • Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
  • 2
    Turn your attention to the small lithium battery-powered digital clock display on the back of your clock. With the correct time zone set, the digital display should accurately reflect the current local time.
  • 3
    Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment.
  • 4
    Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner.
  • Read more: How to Set a Seth Thomas Atomic Clock ' eHow.com http://www.ehow.com/how_6120534_set-seth-thomas-atomic-clock.html#ixzz1GyAcVHP2 hope this helps you
    1helpful
    2answers
    88900 Atomic Clock does not read time and temperature.
    Batteries must come out of both the temperature sensor (transmitter) and base (clock and temperature display). Leave out for about 4 minutes. Replace the batteries in the temperature sensor FIRST and set it about 5 - 10 feet away from the base. Replace the batteries in the base and leave them both set without touching any buttons for at least 15 minutes (usually only takes 5 minutes or so). The temperature should start to display. You can set the clock manually to the correct time and have it get the updates via radio in the evening or night. Should work after all this just fine. (have done it alot of times this way over the years)
    Good luck.
    Skyscan atomic clock receives time signal but is displaying GMT rather than EST.. how do I get it to display EST?
    You didn't tell us the model number but whatever it is, you should find instructions here:
    Skyscan website
    Our various 'atomic' clocks have either a menu that lets one select or a simple slide switch with US time zones from which to choose.
    7helpful
    2answers
    Cannot reset my SkyScan Atomic clock after changing batteries
    Online manual is at link http://skyscan.info/content/manuals/25-model-87315.html
    2answers
    I have a87900 model skyscan,can;t get it reset after replacing batteries
    Just did this after problem resetting after changing batteries, press setover and again til it displays est, then press+until your time zone is displayed, it will also display dst, press +till on/or off depending on your location, then US will appear, clock will then set itself. Good luck, how frustrating.
    Top SkyScan Home Experts
    john h
    ADMIN Andrew
    ADMIN Andrew
    Are you a SkyScan Home Expert? Answer questions, earn points and help others
