Question about Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven
Electric oven clock display not working - Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven
  • Frigidaire
    Frigidaire Jul 08, 2014
    Good Morning Friend, this is Z. I see that your post is listed under Frigidaire wall oven and that the EOC (electronic oven control) is not working. Do you have an electric or gas wall-oven? May I please have your model number? You can typically locate the serial tag, which lists your model number, on the left side, as you open the door. Also, can you elaborate prior to your problem any other symptoms before having this issue? With this information I can assist you better in pinpointing the problem. Thank you!
2 Suggested Answers
6ya staff
SOURCE:
chrispolkele
Electrolux
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
    Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
    Posted on Nov 13, 2012
    Probe light on convection oven stays on. Clock won't display. Oven still works though.
    Sounds like the control board is not communicating correctly with the rest of the unit, consult a professional.
    Aug 10, 2012 | Frigidaire 30" Built-In Single Electric...
    The clock is working , but I can not get it to come on
    What will cause that is a part on the clock that powers the display to illuminate has gone out yet the part of the clock (also called the electronic oven control) that send power to the heat elements is still working.It may work like that for years as long as you done mind the clock not displaying, OR to get it to display the clock/eoc would need to be replaced .
    Gene
    Aug 05, 2011 | Kenmore 47722 / 47724 / 47729 Electric...
    GE Wall Oven Model # JKP07G0D2BG - The clock has quit working. Any suggestions would be greatly appreciated.
    I assume the display for the clock/timer is now blank. If the oven is still working the only thing you are missing is the clock. If you can't do without it you will need a new clock.
    Most of the time the clock/timer stops working it affects the operation of the oven, the oven won't work. If this is the case you will need a new timer unless you can do without the clock/timer. If so a repairman should be able to bypass the clock with ease so that the oven will operate without the clock/timer.
    Feb 12, 2011 | GE 24" Built-in Single Electric Wall Oven...
    Our beko dv 555 w double oven bottom oven is not working as the clock display is not on
    Beko DV 555w Electric cooker.Oven and clock is not working.
    The hob and grill work.
    Nov 19, 2010 | Ovens
    How to set the time on clock
    Have not been able to set the time on clock - the actual model number cannot be found on the oven
    Jul 17, 2009 | AEG D2100-4 Electric Double Oven
    Display light faded and now gone
    Supposedly the electrolytic capacitors on the display board need to be replaced. See: http://applianceguru.com/forum1/18842.html
    Jan 15, 2009 | Thermador SC302T Electric Double Oven
    Electric oven & grill not working no digital clock display
    If there is a display on the clock and you cannot reset it to manual, then the oven will not work, if you cannot reset then you will probably need a new timer fitting.
    They can be bypassed, but not recommended unless you know what you are doing..
    If there is no display at all , then check to make sure you have supply to oven
    Plz rate my solution.
    Thanks.
    Dec 16, 2008 | Neff U1661 Double circotherm super...
    my frigidaire oven will not light. The broiler works and the oven ingiter lights up, but the oven will not ingite. The electronic display does work.
    Aug 25, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Time display
    if the-at doesn't work sounds like you inadvertently turned of the display for clock try holding the clock button for 3-5 secs itll beep and remain on then
    Mar 09, 2008 | KitchenAid KEBC247 Electric Double Oven
    Clock problem
    had same problem but didn't fix it because i don't use the clock. after a few months it got worse, can't set the time (clock always flashing) so the oven doesn't work.
    Jan 21, 2008 | De Dietrich DOC310 Electric Single Oven
    Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven Logo
    61 people viewed this question
    Top Frigidaire Ovens Experts
    Marvin
    Marvin
    Bruce Denton
    Alan Chouinard
    Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
