We have black and white dots on screen, is the bad TI chip covered for repair by samsung.
I don't believe the manufacturer is covering this any longer, but you can try calling Samsung support at 1-800-726-7864
Call 1-888-899-7609
Mon. - Sun. 9am - Midnight (EST)
Hearing-Impaired (TTY)
1-888-899-7608
Mon - Sun : 9am - 6pm (EST)
Home Appliances Hours of Operations
Mon - Fri : 8am - Midnight
Sat : 9am - 5pm
Sun : Closed
Laptop, Printer, Galaxy Tabs (WiFi only)
1-800-SAMSUNG (1-800-726-7864)
Mon - Sun : 24hrs
the part# for your DLP chip is : 4719-001985
see the following web site: http://www.samsung.com/us/support/contact
the
SOURCE: Samsung DLP HL-S4266W White dot problem
Its the DLP IC chip itself that is bad. The DMD board is where the chip resides but if you order a board, it will come without the chip. Its not cheap and the replacement is tricky because the DMD board must be removed and then an alignment of picture centering will be necessary.
michtech
SOURCE: White dots on screen of 50 Samsung DLP
Random dots or pixels failing on a DLP TV will be a bad DMD chip. This is a technician replace item only. The chip runs around 160 dollars list price. The part number will depend on which version the set uses and will be determined by the technician.
SOURCE: White dots appearing on Samsung TV screen and multipling each day
It seems you might have an issue with the dmd board. Go to the menu, and if the dots still show on the menu, the issue definitely is with the dmd board but if they don't come up on the menu, the issue will be with the video board.
SOURCE: Samsung Slim DLP TV white dots on screen Model
No way to fix it solo, but Samsung is aware of the problem. Here's a link to the solution:
http://forums.cnet.com/5208-13973_102-0.html?messageID=3162774&tag=emfrnd#3162774
