Question about Maytag EPIC MFW9600S
Waht to do wtih maytag washer error code E02?
2 Suggested Answers
SOURCE:
appliance765
  • 83 Answers
SOURCE: error code FL-maytag neptune front load washer won't lock
replace door latch (fl = faulty latch ) good luck APPLIANCES R EN
Posted on Mar 10, 2013
What is f03 and e02 error codes on duet dryer[not washer]?
Error codes are pretty generic between the washers and dryers. This appears to be a temperature sensor issue.
whirlpool duet dryer f03 and e02 error code Google Search
Same error on a washer
How to repair whirlpool duet error F3 E2
Aug 20, 2018 | Washing Machines
Fix for error code E02F06 on Maytag mhw7000xw front load washer
I found this reference on the web ... from a repair technician on a Maytag Maxima>>>
So I'm really sorry to bring you this bad news, but let me explain your error codes. F06 E02 is a communication error between your MCU (motor control unit) and your CCU (central control unit). You'll want to remove the top panel, the control panel, and then the front panel of the washer and make sure the wire connections to the motor control unit below the tub are all secure. If everything checks good, you'd need to have the MCU replaced.
From a different reference on a similar Maytag MHW6000XW2 ... also indicating communication issue
capture-o5w4phgx25od3lsv3yfk4e0a-4-0.png Usually ... hidden somewhere on the inside of the washer you will find the service technician paperwork which has all sorts of additional detail.
Helpful?
Good luck on your troubleshooting!
Mar 05, 2018 | Maytag Washing Machines
Maytag maxima ecoconserve washer My washer will not operate. The lights come on as if it will I hear a few noises, but water will not enter it and it does not operate. Error Codes are E02 and F06
you have a communication error from the UI (user interface) to the CCU (Central Control UNIT). It could be the wiring or the control itself
Feb 06, 2016 | Washing Machines
My may tag washer has codes F06 & E02 , what does this mean?
I beleive e02 is something to do with ur drain pump set up clogged or damaged water pump and hoses
Jun 15, 2015 | Maytag MHW6000XG Maxima High-Efficiency...
What are the error code for F09 and E02. for maxima maytag
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 09, 2014 | Maytag MHW6000XG Maxima High-Efficiency...
Washer will not run
f06 OR e02 error code means you have an interface communication error. the main control board isn't communicating with the front interface control board. if you pull the washer out and remove the 3 screws coming in from the back of the top panel. the top panel will pull straight back, up, and off. check all the wire connections between the two control board and make sure they are all secure. if everything looks good, then the interface control board may need to be replaced.
f01 e02 means that your motor control board is not reading the tachometer on your motor when it tries to turn the motor. it thinks that the motor is struggling. open the door and turn the basket to make sure it spins freely.
Sep 28, 2014 | Maytag MHW6000XG Maxima High-Efficiency...
What do these 2 codes mean on my maytag washer , F06 and E02?
The error code E02 and F06 on a Maytag washer could mean that the hot water solenoid went out. It could also mean that that the hot water control is not working properly.
Sep 23, 2014 | Maytag Washing Machines
Getting E02 and F09 error codes on my Maytag Maxima MHW6000XW front load washer
Here is the manual. Hope it helps: http://www.applianceblog.com/mainforums/attachment.php?s=001fc13abc99c02a4aa812a23c01ac7e&attachmentid=13030&d=1381289434
Jan 05, 2014 | Maytag MHW6000XW - MaximaTM...
Maytag Maxima Front Load Washer. F01 / E02 error codes. Power on, kicks off cycle, locks door, but will not call for water.
Tip the machine up & look inside up high, you
should find a bag with the diagnostic service
manual & it has the codes
Sep 04, 2013 | Washing Machines
Maytag EPIC MFW9600S Logo
47 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
