SanDisk Sansa e250 MP3 Player Logo
A
Anonymous Posted on Jul 06, 2014
I want to remove music from sansa sandisk e260
5 Related Answers
A
Anonymous
  • Posted on Jan 01, 2008
SOURCE: SanDisk Sansa E260:"synchronize to continue your music acount"(another problem, yet again)
it means that you need to synchronize your music instead of just highlighting it and pressing copy. It shows up when you have done that and it would play the song until you do what is above.
76guest
  • Posted on Jan 08, 2008
SOURCE: Sansa e260 video question...
You need to use the sansa media converter program that came with the sansa on the CD. This is used for photos and for video. The supported files are listed on the screen once you open it.
Anonymous
  • Posted on Feb 08, 2008
SOURCE: deleting music from sandisk sansa E260 4FB mp3 player
you can change the usb mode in the sansa player settings to MCS then connect it to the computer, in windos xp the device will be recognized automacally. go to the explorer or to my pc and you should see it there.. go to the folder music and delete what you want,, you can copy music as well.
then desconect it safely and restart the device,, It will refresh the database and that's it.
you can change the USB mode bac to MTP if you wish.
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on May 23, 2008
SOURCE: SanDisk Sansa e260 video problem
p.20 of manual:
Sansa Media Converter software lets you convert photos and videos as appropriate,
and then transfer them to your Sansa player. Sansa Media Converter offers
features such as cropping, rotating, and resizing before transferring them to your
player as well as the ability to transfer photo and video files to your microSD card.
Refer to the Sansa Media Converter software for file formats supported.
To transfer photos and videos to your Sansa player, follow these steps:
1. Connect the Sansa player to your computer.
2. Select Converter using Sansa Media Converter on initial connection.
3. Click Add Media to select photo or video files to be converted.
4. The Sansa Media Converter will store all converted files in My Album. Click
the Album Name box and type in the name you want.
5. Click to start the conversion process. A status box will appear
showing which file(s) are being converted.
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Jun 28, 2008
SOURCE: Sandisk Sansa e260 4GB Media Player manual
http://www.sandisk.com/sansa/#/support-0/
5helpful
2answers
How install a driver for Sansa e260
Download the software after you run the link below ....Put check next to converter/firmware update/Manual download...run the programs follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Also make sure you are connected to a 2.0 usb the back of the computer is best (the motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
Can load music on my sansa e260
Try converting the file to mp3 format, then paste into your music section of your Sansa e260
Alittle confused about the Sandisk Sansa e260
yes it will still charge and transfer data....but only if it has the same usb type that connects to you mp3 player...
2answers
SanDisk Sansa e260
if you want to remove ALL songs from you sansa go to my computer right click the icon that refers to your sansa model and click format. this will delete all pictures, videos, voice recordings, preset radio stations, and music. this is the only way i have find to delete music permanently. before doing this make sure you have your files backed up. also you must be in MSC mode to do this.
SanDisk Sansa e260
When it comes to deleting songs, I went on the program I use to get my music on and clicked on the sansa 260 and found my playlist. I bet if you connect your sansa and look around that program, you could probably find your playlist and start deleting.
Can't add playlists
go to computer than click on Sansa e260
- Click on PPI NAND
- Click on PLAYLISTS
- Create a new FOLDER
- Give your playlist a name
- than put the music in it.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
