Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
A
Anonymous Posted on Jul 06, 2014
Lenovo E430 battery plugged in not charging - Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
Garret J.
Level 1:
New Friend:
  • Contributor 19 Answers
  • Posted on Jul 07, 2014
Garret J.
Contributor
Level 1:
New Friend:
Answers
19
Questions
Helped
1616
Points
24
Does the computer stay on while plugged in? If so, replace the battery. DO NOT replace it with a cheap replacement. Please, just trust me. They are garbage. You will be out $15-20 and the time you spent messing with it. Drop the $40-50 and just be done with it.
My lenovo thinkpad e430 keyboard get stop working in between in normal work , what should i do for that
your keyboard has a dust problem. So just clean dust with vacuum cleaner and check keyboard driver is installed then u can work normally and easily
Two beep sound with blank display
removed the battery and charger and try holding the power button for at least 10 seconds then replaced battery and charger then press the power button..
All keypad keys functions as right click
This may be caused by virus. You should check your system in the safe mode and delete any threats.
All keys are working as right click
- Check The Keyboard Options Or mouse options
- might it need a format
- might the problem is from keyboard or mouse
HDMI not connecting
It depends on your operating system to fix this issue.
In Windows 7 click on the audio icon in the bottom right corner and click on the icon above the volume control to select the output while the HDMI cable is connected.
My lenovo e430 will no longer connect to an external monitor (projector)
Video is not coming in my Sony Bravia HDTV while connected with HDMI cable from Lenovo E430. I could hear the sound. Is there any solution for this?
Lenovo Ideapad Z570: Battery indicator shows the Power is plugged in & charging. But the Battery charge percentage doesn't increase. How to fix this?
The battery might be nearing the end of it's useful life and needs to be replaced. The battery only lasts for so long then it has to be replaced.
Buy a battery on ebay base on your computer's Make and model, not the model of the battery.
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
