I want to only use google chrome for web browsing, however, I cannot figure out how to remove the app launcher so i can return to specifically using my google chrome app.
Its a glitch in Google Chromes latest update. just uninstall Chrome remove all its registry keys and left over folders. restart your computer.
then use Internet Explorer only then go to https://chrome.google.com click the download and follow the instructions. The app launcher will not install onto your desktop, but will open to the app launcher page when you open Chrome.
that too can be removed also bu going into settings "Open a specific page or set of pages. Set Pages" click on set pages and add new page to about:blank or to whatever page you want Chrome to open to. then click save. and that is it no more app page.
once i did this Chrome opens a lot faster.
SOURCE: Google Chrome removal
right click on any internet shortcut icon -> select properties and to the right of where it says Opens with: click "Change"
Now you'll be given a list of recommended applications
If you were using firefox it will probably be right there just click it then click "ok"
if the application you used before isn't there click "Browse"
If you want to use Internet Explorer just go to: My Computer -> C:\
-> Program Files then find the folder called Internet explorer, inside you'll find iexplore click it then click open
let me know if that worked ok for you
SOURCE: Unable to work with google chrome
kindly check if you have successfully installed the google crome in your computer/Laptop then you can try to reinstall it again.
SOURCE: my google chrome is not loading the web page
well there are several things why your google chrome does not work. here are some tips:
check if you have another browser other than google such as internet explorer, netscape, firefox , determine if you have internet access
If it has, then uninstall/ reinstall your google chrome..
If it does not then check your physical connections on your pc
check the lights on the modem / router if it is all lit, if it doesnot , contact your modem/router provider. If it works, then proceed to next step:
Then type the "ipconfig" command on the command prompt by clicking start > all programs > accessories > then click command prompt
if the IP address starts with 0.0.0.0 or 169.xx.xx.xx consult your Internet service provider, if it is 192.xx.xx.xx then proceed to next step:
Type the ip address 192.xx.xx.xx on the internet browser, if it replied , then configure your router settings to make sure that the other ip addresses would work on the internet browser. Then type www.google.com or www.yahoo.com if it work. If symptom persist, consult your internet service provider.
Hope this help....
SOURCE: when i install google chrome yhen it works good
1. Set your chorme to use default statup page for google ( E.g. http://www.google.com/webhp?hl=pa )
You can do that by going in OPTIONS -> BASICS
2. Open chorme and you will see google.com is already open
3. Google the name of website you want to browse. ( e.g. type gmail and click search )
4. Right Click the Link to gmail and open in new tab.
5. You have sucessfully opened a new Website in Chorme web browse.
Welcome to the future Web broser. lol </b>
SOURCE: google chrome apps and extensions were deleted
well the easiest thing to do is sync your browser w/your email address. if you haven't done this, there's really no way to restore it unless you do it manually. to sync google chrome to your email do this:
go to the wrench icon @ the top right.
go to options
click the 'personal stuff' tab on the left
the first option is to sync your account, follow the setup instructions.
If you have already done this, there's a button to resync all your settings. good luck!!
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
I had to Delete all Traces of Google even in "Show Apps" and The Regedit all apps had to go Even the Files and got it back
