Question about JVC Everio GZ-MG130 Camcorder
When i turn my camcorder on sometimes its in japanese and has a vertical line through it,why
2 Suggested Answers
SOURCE:
  • 2509 Answers
SOURCE: why does my camcorder start up in japanese and have a vertical line through it sometimes
My guess is that the internal battery (not the main battery) is faulty and it has lost it's stored settings. Try changing it to English and keep it charged, don't let it deplete, see if it retains the setting. As far as the line is concerned, without a proper description its hard to say, but often bright highlights will cause a line down the display because of the way the imaging chip works, that is normal if it is only present with highlights
Posted on Jul 07, 2014
When you turn on set a lot of vertical scramble lines
Turn off, disconnect power for a couple of hours and try it again.
If vertical lines still there google for your model number and vertical lines. If it is an LCD version set then youtube search for your model number and repair. Sometimes it takes a baseball bat!!!!
Feb 10, 2015 | Televison & Video
Why does my camcorder start up in japanese and have a vertical line through it sometimes
Jul 07, 2014 | JVC Everio GZ-MG130 Camcorder
Vertical lines
If the lines appear on the tape this way when it is recorded, then the CCD unit is going out on the camcorder. If it isn't recording the lines then the viewfinder wiring or screen is damaged.
You should problably take it into a camera shop to see if its worth fixing.
Aug 13, 2008 | Canon MV700i Mini DV Digital Camcorder
GR-D33u vertical lines on all screens
you'll need to send it in for repairs.
some contact info for JVC.
Stacy Sample Service Coordinator JVC Service & Engineering 10700 Hammerly, suite 110 Houston, Texas 77043 (713) 935-9331 Ext. 101 ssample@jvc.com
being a fact that JVC camcorders are very trouble prone, it would probably be a better ideal & cheaper to buy a new camcorder.
for your next camcorder purchase, i would stay away from anything made by JVC.
Apr 13, 2008 | JVC GR-D33US Mini DV Digital Camcorder
Sound is ok, but do not record images.
I have had the same problem since I purchased mine 4 years ago and it has been repaired 3x and is in the shop for a 4th. I had the extended warranty and Futureshop refuses to acknowledge that it is a Lemon and should be replaced as they don't consider resoldering wires as a "repair". My unit has been in the service center a total of 12 weeks over the 4 years. The service center recommends Sony Camcorders and the Claim center said they get few Sony camcorders so I would say the Canon problem is an issue that is common. Sorry to say. Mike
Jan 08, 2007 | Canon Optura 10 Mini DV Digital Camcorder
Unable to view or record video
i fear you have a bad CCD. replacement of the same may rectify the problem.
Oct 08, 2006 | JVC GR-D33US Mini DV Digital Camcorder
Vertical lines
This is a defect in the CCD ( light sensor ) - check with Canon and they'll replace it free of charge even if the camcorder is out of warranty.
Jun 16, 2006 | Canon MV600 Mini DV Digital Camcorder
While lines problem
There's nothing wrong with your camcorder. This sometimes occurs when there is a lot of contrast between the background and the subject or object you're shooting. Try shooting from a different angle or adjusting the lighting conditions.
Sep 06, 2005 | RCA CC-432 Camcorder
Problem with JVC GR-D70U
It's ... a. A broken connection. b. A failed chip or component. It is not something an owner usually can repair.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
JVC Everio GZ-MG130 Camcorder Logo
37 people viewed this question
Top JVC Video Cameras Experts
Ekse
Larry Stiles
Larry Stiles
Al Rush
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
